steering wheel squeak when turning=annoying
Old 12-21-2004, 12:12 PM
2001Millrunner's Avatar
steering wheel squeaks when turning, i took the dash apart and apply grease , also tried WD 40 as well, non worked, does anyone else have this problem
Old 12-22-2004, 12:20 AM
884runner's Avatar
it's the connectiong peace that touches the back of the plate on the steering wheel so the horn will work. You have to take your wheel off and use a steering wheel puller to remove the plate to put grease or graphite on the back of it where the connector will touch. the connector is about the width of a nail and should be the only peice of metal sticking out once you remove your steering wheel accembly. I have a grant steering wheel so i have a seperate plate, if you have the stock wheel the plate should be attaced to the wheel. This happened to me and every once in a while i have to re grease it esp. in the winter.
well good luck and i hope this was helpful.
alan
Old 12-22-2004, 05:28 AM
colsoncj's Avatar
Mine does the same thing, just started.
Old 12-22-2004, 06:48 AM
ic, i guess I'll have to take off the airbag which is no fun.... Thanks for the reply =)
rushw
07-18-2015 01:46 PM
voiddweller
07-15-2015 03:56 PM
jon.r
07-11-2015 03:34 PM
skoti89
07-06-2015 07:45 PM
Quick Reply: steering wheel squeak when turning=annoying
