Steering wheel alignment
Old 09-16-2005, 05:34 PM
MorphiasX's Avatar
Ok, when my tires are straight, the steering wheel has to be turned a little bit to the right. I just got an alignment not too long ago, and it was before, and it didnt change with the alignment. It wasnt too bad, but then i ended up driving through a cloud of dust that i couldnt see through and i fell into a ditch, it was about as deep as my 32's and i was sitting on the t-case skid and front bumper (custom steel bumper so no harm done) wasnt a problem, after i locked the hubs i backed right out of it in 4-low, but long story short i bent a rim and was able to fix it, but now the steering wheel is really bad with the mis-alignment. The truck doesnt show any signs of pulling or anything with bad alignment. Can i adjust the steering wheel myself?
Old 09-16-2005, 07:16 PM
4Crawler's Avatar
As long as everything else is adjusted/aligned properly, easy to re-center the steering wheel, either loosen the splined clamp at the firewall and rotate the wheel as needed, or pull the wheel and line it up the way you want it.
Old 09-17-2005, 12:39 AM
MorphiasX's Avatar
Ok, i just pulled the wheel off and aligned it like that... Worked like a charm, thanks.
mussy01
12-13-2016 08:20 PM
Up&Down
08-11-2015 10:04 AM
RBK
08-01-2015 01:55 PM
terminator
07-27-2015 07:13 PM
Quick Reply: Steering wheel alignment
