#$%$ steering control arm
Old 12-28-2004, 05:14 PM
HarrisonP's Avatar
Over the past week I have completely gutted my frontend and put it back together . I removed my differential and replaced all of the seals, put my bilsteins on, put new rotors, calipers, and brake pads on, replaced my lower ball joint, and now I have a problem. I cannot get the steering control arm on my drivers side off. I got the locking nut loose, but can't twist off the arm. I have tried using the wrench, a pipe wrench, I tried to use an air hammer to loosen it up, used penetrating oil, and I just can't get it off. The reason I am replacing it is because the boot over the joint is torn. I have a brand new one ready to go on, but this is really stumping me. I think that I could get it loose with a torch, but I dont want to have to take the big boot off. You have to cut the inner clamp. Any ideas before I have to take anymore things apart????
Old 12-28-2004, 06:41 PM
HarrisonP's Avatar
bump.............
Ernie217
08-14-2015 05:25 AM
mavenator
08-13-2015 01:12 AM
kirkrunner
07-27-2015 07:59 PM
ksmudrunner99
07-21-2015 05:33 AM
1994toyota
07-17-2015 03:03 AM
Quick Reply: #$%$ steering control arm
