Steering Column/Steering wheel moves/wiggles left and right??? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 11-16-2005, 10:10 PM   #1
grimpy's Avatar
Anyone have any idea why this is happening? Worn bushings or something? My steering wheel basically moves left and right a little bit. This is while parked also. I can wiggle it left and right also while driving. Possibly loose U joint or something somewhere? Or is this normal? I highly doubt it but I inspected the shaft and from where I was looking, nothing looked wrong with it.
tia
Darrin
grimpy is offline   Reply With Quote
Old 11-16-2005, 10:25 PM   #2
ASU4runner's Avatar
Yeah I'm thinking my bushings might be worn out because mine has the same symptoms.
They only have 185k miles on them... hmm
ASU4runner is offline   Reply With Quote
Old 11-17-2005, 07:42 AM   #3
osr436's Avatar
grimpy
I had this issue on my truck and found that it was two bolts underneath the steering/dash. You would have to take that bottom dash panel off, the one under your steering wheel down by your pedals.
Once you have that off there are two bolts that hold the steering wheel. It's holds it from moving side to side.
That was my problem. It could be something else but my guess is to start here.
Good luck
osr436 is offline   Reply With Quote
Old 11-17-2005, 02:04 PM   #4
grimpy's Avatar
Quote:
Originally Posted by osr436
grimpy
Good luck
Thanks bro, I'll give it a try later.
Old 11-17-2005, 02:58 PM   #5
grimpy's Avatar
grimpy
Good luck
OSR, nice looking out bro! It turned out to be those bolts...
Asu, try checking those bolts. When I checked to see if it was loose, I gave it a little jerk but it was tight... I decided to give it a good tug and it tightened up more... Now my steering wheel has no left/right play.
Required tools, 10mm for the 4 bolts that hold the lower cover on and 14mm deep socket for the two that holds the steering column in place.
Old 11-17-2005, 05:38 PM   #6
ASU4runner's Avatar
Sweet, I'll try that tomorrow.
Old 11-17-2005, 09:46 PM   #7
grimpy's Avatar
Quote:
Damn... I just messed mine up.... When I tightened it, I didn't center the wheel so it looked a little off... I decided to center it... Lets just say when I retightened, I tightened too hard and broke the thread... The reason why I kept tightening it was because there was still play on the steering wheel... After breaking the thread off, I managed to get the trapezoid block thing out and found out the reason why it wiggled... The trapezoid wasn't lined up properly... No matter how much you tighten, if the trapezoid is off by a certain amount, it may wiggle... The pos thread part is welded on so now I have to figure a way to get the sucker out... Now it's worse than before...
If your's is wiggling and that trapezoid isn't flushed in place... try to push it to flush it... Mine was still off so I may need to remove the trapezoid crap and drill the hole bigger so it will flush after I figure a way to get the POS bolt out and stick a regular bolt back on. I'm wondering why the hell Toyota used this pos trapezoid crap instead of just regular bolts to tighten it...
Old 11-17-2005, 11:17 PM   #8
ASU4runner's Avatar
Wow, i'll try not to make that mistake.
Old 01-26-2016, 07:24 AM   #9
were you guys able to fix this problem? my mother in laws Toyota sequoia is doing the same thing, I took off the plastic around the steering wheel and I didn't notice anything strange/missing/loose, so im guessing it might be the same problem you guys had...if you guys have anymore info on this please share
greatly appreciated
thanks
youngjr_scotty is offline   Reply With Quote
RedRunner_87's aka "Operation Mall Crawler" Build Thread RedRunner_87 95.5-2004 Tacomas & 96-2002 4Runners (Build-Up Section) 60 01-14-2017 05:16 PM
The Rebuild of Lucy. 1982 4X2 Standard Pickup jasonty Pre 84 Trucks (Build-Up Section) 38 10-05-2016 03:17 PM
FS[SouthEast]: 99+ center console, rear air deflector, lift spacers, steering wheel terminator Misc Stuff (Vehicle Related) 3 07-27-2015 08:13 PM
What to do with old tires and wheels? DrZero Tires & Wheels 2 07-13-2015 10:59 AM
This time, science has gone too far! RobotMoose Off Topic Talk 1 07-07-2015 08:36 AM
Tags
95, backing, left, loose, lund, moves, moving, side, steering, tighten, tightening, truck, turned, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
