starting issues
Old 01-06-2005, 01:49 PM
mp101v's Avatar
starting issues
I have a 93 truck. 22re, 5 spd tranny. Sometimes I try to start it, and the starter won't even click. I stop and try again, then it treis to start, but won't turn over. Sometimes it only clicks. Sometimes it turns over, but roughly, then I give it gas and it is fine. Any Ideas?
Old 01-06-2005, 02:12 PM
Adam F's Avatar
Clean up your battery terminals, and your starter to battery connections. Then have your battery load tested.
Old 01-06-2005, 02:27 PM
SoCal4Running's Avatar
Dont skip over the relay wire either, recently had the same problem with my 4runner so I swapped starter with a know good one that I have figuring it was the contacts, replace the battery, main power cable, checked all the grounds. Of course the last thing I check is the stupid relay wire at the starter , it wasnt making a good tight contact and would do the intermittent starting "click". Crimped the conector alittle and fixed it.
Old 01-08-2005, 08:30 AM
mp101v's Avatar
I'll give it a try, thanks.
bigjstang
08-25-2021 12:41 AM
06-01-2021 01:51 PM
Regency
20
01-03-2020 07:43 PM
coryc85
09-09-2015 06:24 AM
Avenged
07-09-2015 07:55 AM
Quick Reply: starting issues
