YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-28-2004, 08:19 AM   #1 (permalink)
Starter Removal woes
I'm having difficulty removing my starter motor from my 95 pickup with a manual transmission.
I have removed the cables and the obvious bolt on the top, but does anyone know where the other bolt is hiding?
I'm feeling pretty stupid right now!
SharkAtaX is offline
Sponsored Links
To remove this ad, register today!
Old 05-28-2004, 09:40 AM   #2 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Did you look at the writeup in the tech section? I followed that one and one from 4x4wire.com when I did mine. They helped a lot.
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 05-28-2004, 09:51 AM   #3 (permalink)
Jboy's Avatar
I never did a 95 Toyota so I can`t help you there but one thing I can recommend is the Haynes Auto Repair book for your truck. Everytime I get a used/new auto I purchase the book pertaining to vehicle. It is very helpfull in situations like these, even has pics. Good luck.
__________________
2000 4Runner
2" lift, not Frankenstruts, OME 906 rear springs/OME shocks
MT/R 285/75R16 on AR Atlas 16x8
Offroad Solutions Manual Hubs kit
Jboy is offline
Old 05-28-2004, 02:01 PM   #4 (permalink)
Gabe's Avatar
try the "search" first, there is a great writeup out there that I used about 6 months ago. I believe the bolt that you are missing is on the rear of the starter, facing the rear of the car. I used a 20 inch extension on a ratchet to get it out. Its up there but kinda tricky to find...good luck.
Gabe is offline
Old 05-28-2004, 04:06 PM   #5 (permalink)
Find the write up by jimrockford. Make sure you remove the right bolts. If they are obvious and easily accessible, they are not the right ones. Use a long extension and a u joint on your ratchet and it's not too bad. I did this a couple months ago too and it was fairly easy to follow the steps in the write up.
J.D.
__________________
95 4runner, SR5, 4wd, 5 spd, ext. rear diff breather, Downey HDs, Bilsteins, 32" BFG AT's
surfrig is offline
Old 05-28-2004, 08:26 PM   #6 (permalink)
3.0 or 22re? If it's the 22re, get a fuel filter while you are at it. It will be the one time you put a fuel filter on it that will seem like it was almost fun to do. Having the starter off will be a huge bonus.
Fahrenheit 451 is offline
Old 05-28-2004, 09:27 PM   #7 (permalink)
Hyperlite's Avatar
I have taken mine out 3 times on my 3.4l and it sucks, alot easier with a 2" BL
__________________
  • 97 4Runner Limited front Fox 16" Coilovers
  • 98 BMW M Roadster "instant donuts, instant joy"
  • 69 Bronco Half Cab
  • 88 4Runner
http://s263.photobucket.com/albums/i...view=slideshow
Hyperlite is offline
Old 05-29-2004, 11:27 AM   #8 (permalink)
98 Joes's Avatar
It sounds like you are missing the bottom bolt. The head faces forward. You can get at it by using a long extension and a universal joint. It's a long reach to it, but try to put you finger of one hand on it and guide the socket onto the bolt. All of this being done while lying on you back under the truck.
Also, when it's all loose and ready to come out, I recommend removing the small heat shield from the exhaust that you can see with the access panel removed. It makes removal and installation much easier.
I did mine a few weeks ago for the first time and it was a PITA.
Good luck.
__________________
Doug
'94 4Runner SR5
'98 Honda CBR600F3 SJR
98 Joes is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
woes of front diff removal... KyleT 95.5-2004 Tacomas & 96-2002 4Runners 2 12-13-2006 09:25 AM
starter removal help northfacer581 95.5-2004 Tacomas & 96-2002 4Runners 14 04-17-2006 07:00 AM
Starter Woes...Help! Mavericktoy81 95.5-2004 Tacomas & 96-2002 4Runners 1 03-11-2005 01:52 PM
starter removal surfrig 95.5-2004 Tacomas & 96-2002 4Runners 1 01-04-2004 01:01 PM
starter woes kernel 95.5-2004 Tacomas & 96-2002 4Runners 0 08-02-2003 08:58 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
