Starter/cost/difficulty to install
Old 08-23-2007, 08:24 AM
jminz's Avatar
So i believe that I'm losing my starter. Every once in a while when i turn the ignition it will just click, then finally catch and it will start. My question is how much will a starter run me, and how difficult is it to install myself.
Thanks,
Jacob
Old 08-23-2007, 08:48 AM
eric-the-red's Avatar
Here's a write up on replacing the starter
https://www.yotatech.com/forums/f128...4runner-76347/
Or you could try just replacing the contacts
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
Old 08-23-2007, 09:37 AM
Potomacduck's Avatar
Seriously consider replacing the contacts. They cost me $14.00
A new starter for my '99 was around $295.00
It was kind of a pain, but only took me a little more than one hour.
Old 08-23-2007, 03:19 PM
jminz's Avatar
ok, thanks guys
Old 08-24-2007, 09:41 AM
NHS
NHS's Avatar
Another artickle,
Read my 2 last post. Worked for me alot easier IMO.
https://www.yotatech.com/forums/f2/3...-heavy-105098/
Old 08-24-2007, 10:22 AM
mkgarrison5's Avatar
so when a starter goes "bad" its ususally the contacts only?? how long does teh starter iteself normally last?
Old 08-24-2007, 10:58 AM
bratliff's Avatar
Toyota's starters are way over engineered (like most items) so the starter itself has roller bearings and is very sturdy... Get the contacts.. I would expect it to last pretty darn close to forever..
Old 08-24-2007, 11:11 AM
cool deal... i heard it was a royal PITA though... at what mileage are you guys seeing contact issues?
Old 08-24-2007, 06:11 PM
CyMoN's Avatar
my starter lasted 160k at that point it it did the sometimes start sometimes not start thing when I took it in to get it tested you could hear sand and gunk grinding in it
Old 08-24-2007, 06:30 PM
jjrgr21's Avatar
rebuilt was $100 and easy to replace
Old 08-24-2007, 11:08 PM
Tonster's Avatar
I just replaced mine twice in the past week. First time I used a starter from the local auto part shop. It failed after 3-days. I got my $$$ back, however I lost my core as it was already collected. I bought an OEM unit and am good to go. I will say the Toyota starter was actually larger and more of a HD unit compared to the junk I got from Advanced Auto Parts. Save yourself the time and energy and just go OEM. I picked up mine locally after buying it online...it was right at $200.00.
Old 08-25-2007, 12:13 AM
rocket's Avatar
look here...
https://www.yotatech.com/forums/f2/3...ips-how-89042/
nvdesertrunner
05-11-2020 08:18 PM
wwjr
09-07-2015 09:27 AM
punks_is_4x4
08-21-2015 01:35 PM
Esibnitsud
07-30-2015 08:19 PM
Quick Reply: Starter/cost/difficulty to install
