Starter bolt problem 3.4
Old 08-16-2007, 08:02 PM
JEDI87's Avatar
I am replacing my starter and I went to lossen the 2 starter bolts and they just won't budge and they rounded some what. I sprayed pb on it but what else do you reccomend to get those bolts out?
Old 08-16-2007, 08:46 PM
LuminoZ's Avatar
Make sure you are using a good quality six-point socket. A little penetrating lube, like WD-40 never hurts, but be careful of overspray. A little careful filing can remove the rounding if you slipped a wrench.
one more thing. Cresent wrenches are not for working on cars. That is way why we have open end wrenches.
Old 08-16-2007, 10:16 PM
rocket's Avatar
I bet one of these threads will help ya...
https://www.yotatech.com/forums/f2/3...ips-how-89042/
Old 08-17-2007, 09:56 AM
JEDI87's Avatar
Thanks, I'm not having a problem getting to the bolts, just getting them to turn, especially now that part os them are rounded now. I even wasted 18 bucks on one of those gator grip sockets, no luck.
Old 08-17-2007, 04:01 PM
86tuning's Avatar
You're going to need to heat and beat those bolts to get them to loosen up. After that, when you put NEW bolts in, put a dab of neverseize on them, and torque them to spec.
Time to take it to a shop and open up the chequebook.
Old 08-17-2007, 04:48 PM
CJM
CJM's Avatar
Simple fact is heat them up a bit if possible and try, that dont work time to get some of those craftsmans bolt off things and use that.
Old 08-17-2007, 05:40 PM
JEDI87's Avatar
I'm wondering if I use my air hammer to try to loosen them if that'll work.
Old 08-17-2007, 06:40 PM
Adam F's Avatar
Air hammer? That will just mangle them even more.
If it comes down to it, go find a snap on truck and get their special sockets they make for rounded off bolts. I used a set my buddy has. I honestly didn't think they would work since the bolt was so rounded, but it worked like a charm! I think they are $99 for the set.
Old 08-17-2007, 06:52 PM
CJM
CJM's Avatar
Same things sears sells really, I wouldnt spend the bucks on the snap ons when you can get a set at sears for half that. Oh Irwin makes the same ones for about 35 bucks sold at casa de depot and lowes.
Old 08-17-2007, 06:54 PM
Adam F's Avatar
No, I'm not talking about the extractor type of deals with the reverse threaded teeth that bite down on the bolt. Snap on sells a set of sockets that have a special design to them that will grip up to 50% rounded bolt. Looks just like a regular socket but has some funky ribs in it. Never seen them anywhere else.
Old 08-17-2007, 06:57 PM
CJM
CJM's Avatar
I know what your talking about, and yes these are special sockets that fit over the bolt itself and have gripping teeth in'em that work. They have both an area for a wrench and a socket/gun. Like I said sears sells them but irwins are the same thing an cheaper http://www.irwin.com/irwin/consumer/...rwinProd100512
Snap ons are similar and I have used them, but these work just as well and dont cost $$$
Old 08-17-2007, 07:02 PM
Adam F's Avatar
Nope, thats not it. They look virtually identical to regular sockets, but they have just a little different contact points than a regular sockets. never seen them anywhere else but the snap on truck.
Old 08-17-2007, 07:03 PM
Adam F's Avatar
Seems that mac sells a similar set too
http://toolmonger.com/2007/05/25/mac...cket-set-line/
Old 08-17-2007, 07:05 PM
Adam F's Avatar
I have a set of the extractors, and I've had limited luck with them. About 20% success rate. I think the snap on set would work a lot better.
Old 08-17-2007, 07:07 PM
CJM
CJM's Avatar
To each his own, at the shop we didnt bother with the mac/snapon/matco ones they want to much, I got all the irwin ones for about 200, thats all bolt sizes, lugnuts and whatnot and using impacts I cant beat them.
Honestly though, tracking down one of thier trucks spending 100 bones for a set and whatnot is not something I would do when I can go to the depot and spend 30 bucks on a set.
Old 08-17-2007, 07:14 PM
Adam F's Avatar
I agree, snap on and all those tools are too expensive. Personally I have all craftsman and harbor freight tools in my box. Cant afford anything more.
But I was very impressed with this particular socket set, and I might buy it myself. But I'm a mechanic and I would use it more often than a backyard mechanic would, so it's worth it to me.
Sorry for the hijack!
Old 08-17-2007, 07:44 PM
CJM
CJM's Avatar
Makes sense, yea sorry for the hijack.
I sometimes just use a cheap 12pt socket and hammer it on and voila it works.
Old 08-18-2007, 02:09 PM
JEDI87's Avatar
Got it! I went to Ace hardware and bought an extractor kit and went to work. It took awhile as you have to tap it on with a hammer and there isn't really any room to hold it on with one hand and hit with the hammer. Anyway, they finally came out. Thanks for the help.
Old 08-18-2007, 07:14 PM
Adam F's Avatar
Good to hear. Make sure you get some new bolts.
Old 08-18-2007, 07:34 PM
JEDI87's Avatar
Oh yeah, these are nowhere near reusable
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
ZONAYODA
07-13-2015 07:17 PM
Snort
07-09-2015 03:58 PM
colinmil
07-06-2015 04:03 PM
Quick Reply: Starter bolt problem 3.4
