YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 06-25-2009, 12:23 PM   #1 (permalink)
Personal Sales Rating: (0)
Is it the starter?
1999 4Runner - Recently I have been getting the 'click click' when trying to start. Doesn't happen all of the time, but when it does sometimes it'll start after a few tries. If that doesn't work I attach a battery pack and it'll always start. Replaced battery (costco), but it still happens.
Read all of the posts about replacing/troubleshooting starter and have new contacts. Before I pull the starter wondering if that is the issue since it'll always start when I attach battery pack.
Checked voltage and always around high 13/low 14 volts.
Thoughts?
fxtec is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 06-25-2009, 12:28 PM   #2 (permalink)
hross14's Avatar
starter if the volts are right-As the starter gets older it takes more power to--well--start. That could answer why it starts with a jumper.
Also check your cranking amps--
__________________
Yes, I said "country." America really is a nation, but you couldn't convince those who lead the Democratic and Republican Parties of that. Both parties now see America as nothing more than an economy, a marketplace, and not a sovereign nation. They don't see you and me as citizens of this great nation; they see us as units of labor, consumers and taxpayers.
Yes, I am here to collect my 238$ worth of stock from AIG.
"What do you mean a free market economy doesnt apply to the rich?"
hross14 is offline
Old 06-25-2009, 12:37 PM   #3 (permalink)
scuba's Avatar
Id say its a yes on the starter..
When mine was on the way out it would take a few tries turning the keys..
I replaced the contacts and all is well
Props to you for searching though.
Welcome and good luck fixing it..
__________________
SHUT UP AND WHEEL.
My 99 Tacoma Single Cab build.
Now representing All-Pro Off-Road. Call us for all your suspension and armor needs. 951-658-7077
scuba is offline
Old 06-25-2009, 02:19 PM   #4 (permalink)
x2 on replacing the starter contacts now. I had the same symptoms but put off fixing it because the problem wasn't too bad.... Like Buhundred said- One day the starter kept cranking and would not disengage from the flexplate. I made the mistake of trying to move the truck to get it to disengage and ended up cracking the flexplate.
-Scubaduck
ScubaDuck is offline
Old 06-25-2009, 03:45 PM   #5 (permalink)
KrashDH's Avatar
I had the same issue with my tacoma. 99% sure it is the contacts. I replaced mine and she is fine again...here is my thread.. in the photos you can see the worn battery side
http://www.yotatech.com/f2/possible-...-issue-184572/
I don't have a 4runner but I can imagine things are pretty close.
__________________
'99 Tacoma 5spd 2.7 4WD Xtra cab TRD
K&N Intake, headers, Hella's, Magnaflow cat,
cat-back w/ Magnaflow exhaust, gray wire,
fosgate(s), Kenwood deck. Hopefully more to come.
'05 Banshee scream 5th element rear, setup for 7/7-->'06 custom welded steel DJ/trials frame.
Line-X frame coat. Avid BB7 mech. My first frame job. holding strong
KrashDH is offline
Old 06-27-2009, 08:46 PM   #6 (permalink)
Ron Helmuth's Avatar
have a fire extinguisher handy and keep it in the truck so you will not need it.
Other members have had this happen leading to a fire.
Yes it does sound like it probably is the starter contacts however you have not mentioned the cables nor the ends of them. Are you sure they are corrosion free and well crimped at both ends? They sometimes pull out just a bit from the connector.
I am thinking when you attach the jump starter it initiates more pressure on the cable end thus making a solid connection. Total mileage on the vehicle is what please?
__________________
99 4Runner SR5 4wd 3.4/5 spd-
Factory Locker
O/M/Emu springs- 881 fronts/890 rears
O/M/E shocks- N91s fr/N86 rr
All Pro Off Road welded on sliders
ARB"Taco"bumper/Hella 500s & side markers
Redline Tuning hood struts/Bushwackers
2" 4crawler.com body lift
all my Yota photos are over on Facebook now
http://www.facebook.com/album.php?ai...5&l=5795132731
Ron Helmuth is offline
Old 06-27-2009, 08:50 PM   #7 (permalink)
algranger's Avatar
Starter
__________________
DIRTY DIESEL
She aint purrin,
She's damn sure growlin
algranger is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2000, 4runner, starter, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
