"Standard" Duel Electrode Spark Plug Life Span?
Old 05-13-2007, 10:29 AM
icerunner's Avatar
I own a 99' 4 runner 3.4L w/ 134,ooo miles
and have heard at least 1 tech at Toyota who said the "standard" duel electrode plugs could go for 100K!!!
I think this is wrong as "Toyota" Recomends 30K mile change intervals for standard plugs
I have changed mine twice:
1) changed mine w/ NGK's at 78K Miles after knocking and performance issues
(they looked like Shi*... with large gaps worn conductors, discolored)
2)Change W/ NGK's at 132K miles (plugs did look better but were clearly aged) and i noticed a big increase in power.
What kind/brand of spark plug did you run?
At what mileage have you guys changed your spark plugs?
How did the older plugs look at the specific mileage they were changed at?
When changed, did you notice a power or performance increase?
Old 05-13-2007, 03:34 PM
Elton's Avatar
changed mine with factory oem denso plugs pretty sure they had around 50k on them and the wires had 137k on them was running just fine but i changed them anyways they looked fine didint notice any change
Old 05-13-2007, 03:52 PM
Jdizzydub's Avatar
Denso oem, supposedly the iridium gets a significant increase in hp. I was using bosch platinum till I read a horrid post on how crappy they were. When I pulled them they were seriously toast. I did notice better throttle response and highway pick-up. Stick with the oem that's waht they were designed for. I check mine at every 7k.
Old 05-20-2007, 10:58 AM
icerunner's Avatar
Hey, Isnt Ngk's Oem???
HEY,
ISNT NGK plugs OEM to???
Old 05-20-2007, 11:08 AM
nick-m's Avatar
Yes - sometimes the factory used Denso in one bank and NGK in the other. This was my case.
Old 05-22-2007, 08:15 AM
Texas_Ace's Avatar
Ditto that here, half was NGK and half was denso.
I got OEM from the dealer for mine. An going to put them in this week if it will stop raining!
Old 05-22-2007, 03:10 PM
toyota_mdt_tech's Avatar
Its 30K its a waste spark system, so it sparks every piston stoke, but only uses every other one for combustion. If you go to a single electrode, its 15K, double plantinum, 60K, double irridium, 100K, single iddidium, 50K... you see the pattern.
Eggslinger
06-08-2019 03:32 PM
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
Alex Bessinger
08-31-2015 09:17 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: "Standard" Duel Electrode Spark Plug Life Span?
