Standard Center Diff Lock?
Forgive me for being a noob on this, but here goes:
My 01 has the center diff lock. Do I really need to get an arb or similar? What's the difference? Is what I have useless for anything serious?
Senior Member
I believe the center diff lock has to do with how power is distributed between the front and rear axles. When it is enganged, you are in full time 4wd. When it is disengaged, you are in standard 2wd.
A locker (like the ARB) is specific to one axle - meaning it controls a pair of wheels. When engaged both wheel on that axle turn at the same speed. This prevents one wheel from spinning freely (taking all the power) while the other wheel sits there not moving.
Does that make any sense?
Originally Posted by Yotatech FAQ
9. What is a locker?
A "Locker" is short for differential locker. It's almost like a limited slip differential (LSD) or Positraction, but it's much better for off roading.
An open differential (that is, one without a LSD or locker) will always send the most power to the tire with the LEAST traction. That's why when you burn rubber only one tire left a mark on the road. It's even worse when one tire is on sand or ice, that tire will spin and the truck goes nowhere.
An LSD helps a little by using clutch plates or gears to send more power to the other tire. This is fine for sand, snow, or ice, but when you are off roading it is quite easy to lift a tire completely off the uneven ground. When this happens to both the front and rear then the LSD can only do so much and all the power goes to the tires in the air and you go nowhere.
A rear locker will positively lock the left and right tires together no matter what. This is the ultimate traction device used for off roading. However, when traveling on icy roads they can send you out of control because when you go around a corner the locker forces the tires to slip (remember, they have to travel different paths).
To remedy this potentially dangerous condition some manufactures make the locker selectable or ratcheting.
Newer 4Runners have a selectable center lockable diff. so that one can drive on hard packed surfaces. This is NOT the same thing as the selectable TRD rear diff lock found on the Tacomas and the '96-2000 4runners. The center diff lock does just that, it locks the center differential only.
Hi,
When you push the 4WD button on the transfer lever, and the transfer lever is set at H2/H4, you are engaging 4WD Hi-Range with the center diff in the open (unlocked) position. You can use this mode while on hard/paved surfaces without binding the driveline.
When you shift the transfer lever to H4L, you are still in Hi-Range 4WD but the center diff is locked. With the transfer lever in L4L, you are in Low-Range 4WD with a locked center diff. In both cases (H4L & L4L), it is not advisable to use this while on hard/paved surfaces as it will result in driveline bind, thereby increasing wear & tear of the front diff, transfer case, CVs, and tires.
HTH.
HTH.
To answer his specific question about whether he needs a locker or not- depends on what you're looking to do. Don't let anyone convince you that you "have" to do anything on this board. It just makes alot of the members feel better about all the money they spent on their own mods they "had to have." Anywho, I think that with the center diff locked, you can still get one wheel on either the front or rear axle to break loose independent of the other, although you'll always have power going to both the front and rear. So, picture a situation where one side of your vehicle is in a muddy ditch (both right side tires in the mud). I think that even with the center diff locked, you'd still be stuck (both right side tires spinning away). A rear locker would likely be able to get you out of that situation by giving power to the left rear tire sitting on solid ground.
There's an amazing amount of speculation and misinformation in this thread.
Commonly when you hear people speak of "lockers", they mean locking the differentials in the axles themselves, not in the transfer case. A center locking differential when locked, forces an equal amount of power to the front and rear axles. When unlocked, it's an "open" system, meaning it send the power to the axle that has the least traction, unless there is a traction control system on top of it. The idea behind having a center "differential" that unlocks is that it is safe to use the four-wheel drive system on hard surfaces. No binding between the front and rear will occur. On vehicles, like the Tacoma without center lockers, you can get binding in the drivetrain if torque cannot be released by wheel spin.
In order of traction;
2wd open axle
2wd locked axle
4wd open axle open center
4wd open axle locked center
4wd locked axle locked center
Locking your center puts you on even footing with a Tacoma where the center is always locked. You will still need lockers in the axle(s) to turn that beast into an offroad machine.
From Edmunds;
"Center locking differential and/or low-range gearing: Both of these features enhance vehicle control in extremely hilly or slippery situations. A center locking differential locks 50 percent of the engine's power to the front axle(s) and 50 percent to the rear axle(s), so as to optimize motive traction"
From Autotrader;
"Center-Locking Differential
On all-wheel drive vehicles, a third differential in addition to those for the front and rear axles. This third differential allows the front and rear wheels to turn at different speeds as needed for cornering on dry pavement. On slippery surfaces, it sends equal power to both axles, either automatically or manually depending on the system, for greater traction. "
2wd open axle
2wd locked axle
From Edmunds;
From Autotrader;
justdifferentials
Just Differentials
08-15-2015 05:25 PM
WTB[MidWest]: Looking for 5spd harness, front axle- 1990 truck
dfarr67
07-30-2015 07:08 AM
Steven.m.paulk
07-24-2015 01:44 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
