Stalker finally joined!
I have been reading posts here for months, but just finally joined. Great info here! Question one. I have been following all the RB body lift posts, and done plenty of searches. I would like to gather in one thread if possible how many people have gone with the 2" on an automatic 3rd Gen, and who had to extend anything other than steering? And, has anyone had problems with tightness in the steering system post install. Thanks all
Aaron
2001 SR5 4X4
Aaron
2001 SR5 4X4
It would be easier to install a coilover kit rather than the body lift. You would also have better overall control as your not lifting the body off the frame causing a top heavy vehicle. M.O.
That will be coming in about a year or so, but I am going slow as money allows, and the body lift is the right price to start. I am only running 31x10.5's on 15x8 AME 201's right now, and am already rubbing. I can fix that with a little trimming, but figure I will eventually need the body lift anyways. Might as well start there. Thank you for the reply.
Aaron
Aaron
Easier to install a coilover kit? Body lift = couple of sockets, 2x4 and a jack. Doesnt get much easier...
Re: Stalker finally joined!
Aaron
2001 SR5 4X4
Aaron
2001 SR5 4X4
https://www.yotatech.com/forums/show...y+lift+install
PM me if you have any specific questions!
Brian
Thank you wabbit. I have read your writeup, and that is what got me started thinking on the 2" over 1". But it seams every Runner has had to do different amounts of modding for the same lifts. So far you are one of the few 3rd gens I have seen with the 2". If I knew it was going to be as "hassle free" as your install I would go with it. I was just wandering if anyone else had any stories, good or bad. Thanks again
Aaron
Aaron
Before
Aaron
Aaron
Brian
I was more worried about having to extend the AT and transfer case levers, not knowing how much of a pain it would be. But, since no one seems to have anything negative to say, I guess I can take that factor out of my decision. Thanks all
... If I knew it was going to be as "hassle free" as your install I would go with it. I was just wandering if anyone else had any stories, good or bad. Aaron
Not exactly sure when I'll be able to install it, but I'll be glad to let you know.
Please do. I am also considering a RB body lift, but I must say all this steering adjustment/bumper adjustment stuff has me worried.
Someone talk some sense into me!
I wonder how a BL would effect my slider positioning? Any thoughts? I would assume 1.5" wouldn't make much difference...
Ugg....a 2 inch BL is really no big deal. Roger includes EVERYTHING you need to do it. Takes around 3-4 hours depending upon your workforce (a spare set of hands helps out greatly). The only 2 things you need to really play with are the steering and the trans linkage...BOTH ARE EASY TASKS!
I would really like to know who had major problems installing this kit. It's really easy to do...plus the number of us with the kit is growing...we are here to help.
As far as impacting your slider positioning...yeah, it will be off. But the impact will depend how they were built. Are yours made to use the pinchweld as extra stability?
Body Lift
I was apprehensive too guys, at first. But I had NO PROBLEM doing the 2" RB body lift at all. His instructions are really good on his sight and with my write-up and several others, you should be able to do it in an afternoon EASY!!! IT IS NOT HARD, it just takes a while and some time to do. Another set of hands also helps!
Just PM me if you have any specifics and I'll put your mind at ease!
Brian
Brian
Ok, well I am very mechanically inclined...so you guys have me convinced. As for the pinch weld on my sliders....hmmm. I dont know.
I dont think it really matters much, as I never plan on "using" my sliders. No one ever really plans on it, do they? Well, there are some crazy's on here that probably do!
Well for just bumping around some trees or sliding around some rocks...i highly doubt it will matter. But, if you use them to protect a rock from jumping up underneath you...it might be an issue. Basically, Im not sure weather doing poser shots with a highlift on your sliders is a good idea. But it all depends how they were built...
You Can Do It!
You can do it. It just takes some time and patience. Having the right tools helps a bunch too. I had a guy helping me who had done many before and it took us less than 3 hours. I would think it should take someone no more than 6 unless they just didn't prepare ahead of time and didn't have any help.
I'll be glad to help in any way!!!
How's that for encouraging!!!
Brian
scott90
10-04-2015 09:21 AM
zombie_barbarossa
10-02-2015 10:54 PM
