YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 03-01-2008, 07:41 PM   #1 (permalink)
SS lift... help me choose
ok so i blew out the shocks in my 97 4runner 5spd 4wd. you all know ive been looking around for my best option and changing my mind about 500 times. but I finnally settled on a Sonoran Lift either the #1 or 7. Im one of those people that like the best but the cost was kinda swaying me. Anyways so Im gonna be running 265/75r16 mostly due to this is a DD and mabey twice a month sees a trail. Ill be running Geolandar ATs.
My runner has stock bumpers but I plan on adding sliders soon and I already have a class 3hitch. I also have about 200-300lbs in the rear almost all the time as well as towing a small motorcycle trailer about 400 miles a month.
I know steve would be the best to ask but I want to hear your inputs as well.
Thanks for the input!
Misfit4Runner is offline
Sponsored Links
To remove this ad, register today!
Old 03-01-2008, 08:31 PM   #2 (permalink)
Taro's Avatar
The 7 sits level but if your carrying all that weight all the time and towing it might sit low in the back. I'd go with the System 1.
Taro is offline
Old 03-01-2008, 09:12 PM   #3 (permalink)
I was thinking the same might as well get the system 1 and if I go system 1 can I run 305/70r16 with mild trimming? or is 285/75r16 my max? without a whole buch of hammering and hacking? I meen really the only think between the 285 and 305 is width. mabey 1 in wheel spacers?
Old 03-01-2008, 09:32 PM   #4 (permalink)
4Runner202020's Avatar
i got OME 883's with the toytec top plate spacer and 890's with a 1 1/2 coil spacer in the rear no body lift and am runnin 305's no problem. 315's fit but i didn't wanna have to re gear so soon... but then again i got custom front and rear bumpers and hi clearence fiberglass fenders... just a thought.
__________________
96 4Runner, 4in lift (883's w/ top plate spacer, Land Cruiser's 8 coil) Pro Comp Xtreme AT 315/75/16's. rear e-locker
I UNDERSTAND THE WHOLE JEEP THING THATS WHY I HAVE A TOYOTA!!
4Runner202020 is offline
Old 03-02-2008, 01:11 PM   #5 (permalink)
Nate08's Avatar
Send a message via AIM to Nate08
System 7 will also ride more harsh than system 1.
__________________
Nate
[/font]
Suspension: Tundra TRD Fronts w/ Dual 3/8" "TerraBull" spacers: 2.5",Trekmasters, LC's/OEM LC Shocks: 3.5"...
Performance: 4" Deckplate, TrueFlow Air Filter, ISR Mod...
Shoes: 285/75/16 Nitto TG's, OEM 16x7 (6 spoke)...
Armor: Stubbs Sliders...
Exhaust: 18" Magnaflow SIDO, Magnaflow High-Flo Converter, 2.5" and 2.25" piping...
Other Necessities: Custom Extendable Panhard Bar, Custom Bumpstop Drop Brackets, 1" Diff Drop...
Nate08 is offline
Old 03-02-2008, 01:59 PM   #6 (permalink)
rdang's Avatar
With all the research I did prior to purchasing my suspension lift, the SS 1.1 was the only lift kit that I could find that no one was bad mouthing, every other kit I saw had some sort of negative feedback.
If you want the best, it's going to cost you.
__________________
97 4Runner LTD :: Sonoran Steel 1.1 Lift Kit | 33x12.5x16 Swamper SSR's on 16x10 Eagle 058 | 4Crawler 2" BL | Trail Gear Rock Sliders | OEM Rear E-Locker
98 Land Cruiser :: UZJ100 on 18" Tundra wheels | OEM Rear E-Locker
rdang is offline
Old 03-04-2008, 05:39 PM   #7 (permalink)
Well I got a steal on some 245/75r16's Goodyear MTR's like new 5 for 500 so I couldnt pass that up. And I ordered my SS 7.2 lift as well. Ill post pictures when I install it hopefully the 18th or 19th of this month. And hopefully after that building my sliders and prerunner bumpers (not a fan of the ARB style bumpers). Thanks all for the help
Old 04-02-2008, 01:24 PM   #8 (permalink)
you have a transmission/steering cooler installed?
mayfield is offline
Old 04-02-2008, 01:26 PM   #9 (permalink)
rdang's Avatar
No... should I?
Quote:
__________________
rdang is offline
Old 04-02-2008, 01:49 PM   #10 (permalink)
mpavolka's Avatar
No... should I?
I don't know why this thread went to this but if your 4Runner is an automatic there is a tranny cooler in the radiator.
__________________
99' 4Runner SR5 5spd 3.4L
Sonoran Steel 7.1/7.2/OME891
Previous Vehicles: 1985 4x4, 1990 4Runner
mpavolka is offline
Old 04-02-2008, 01:52 PM   #11 (permalink)
mpavolka's Avatar
Quote:
I have never owned or ridden in a truck with Cruiser Coils but I have the rear system #7.2 with the exception of OME 891's and I think it rides very well, better than stock or Downey springs I have owned. I can only imagine that the OME 890's would ride better, however I haul and tow a lot of weight.
__________________
mpavolka is offline
Old 04-02-2008, 01:54 PM   #12 (permalink)
Quote:
I should have sent him a private message asking him the type of transmissions he had. I purchased a SS 2.1 kit today, and will run 305/70/16 MTR's. i just wanted to know if fluid temps increased requiring him to install or upgrade cooling. thats all
mayfield is offline
Old 04-02-2008, 02:00 PM   #13 (permalink)
rdang's Avatar
Hahaha - sorry mayfield, thought you were taking a shot.
I have an automatic - I wasn't aware that I need any additional cooling for my 33's. Most guys on here recommend the transmission cooler and break upgrades if you go with a 35" tire, not a 33 so I never bothered.
Whether the fluid temps increased or not, I don't know - I would imagine that they did a bit, but I've driven an hour straight on the highway and no problems. Hope that helps.
__________________
rdang is offline
Old 04-02-2008, 02:30 PM   #14 (permalink)
haha, no problem
Okay, i read the same thing on the forums that a cooler was required with 35
" ..I just wanted to check with you to see if you were experiencing any problems. this is good news for me! thanks for your post
mayfield is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Lift and tires dilemma - help me choose! Asha'man 86-95 Trucks & 4Runners 19 12-22-2007 01:07 PM
Help me choose please: T-15 or T-17 98LimitedCustomized 95.5-2004 Tacomas & 96-2002 4Runners 21 10-14-2005 05:06 AM
you choose! Localmotion Off Topic Talk 9 09-17-2004 09:15 PM
help me choose please HotBacon 95.5-2004 Tacomas & 96-2002 4Runners 14 04-24-2004 12:24 AM
Which CB would you choose? rwmorrisonjr 95.5-2004 Tacomas & 96-2002 4Runners 11 10-26-2003 12:12 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
