SS#7 install tips - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 09-06-2007, 08:33 PM   #1 (permalink)
Henrythewound's Avatar
I need some SS#7 install tips
Hey all, I picked up a 7.1 system a few weekends ago, Steve is a real nice guy, very willing to answer questions and offer tips etc. Anyhow I am probably going to have a buddy of mine help me out with the install this coming Sunday. He used to work as a toyota mechanic and has a whole bunch of tools and access to a garage, so I hope all will go well.
I am looking for any tips/tricks from any of you who have do an install already. I'm specifically interested in any tips not covered in the detailed pdf available on Steve's site. Are there any bolts I should spray some lube on to get them loose? Any tricks for getting at some of the tough bolts to remove the shocks? I seem to remember someone mentioning some were tough to get at and they had to essentially ruin the existing shock to get it out.
I attempted to search but I swear to god the search function on this site sucks. I can rarely even find threads I know the words to the title that I posted myself.
Thanks everybody,
~Joe
__________________
Joe aka Henrythewound
2000 Toyota 4Runner 4WD, Stubbs SKO sliders, SS 7.1, 265/75/16 BFG ATs
An adventure is only an inconvenience rightly considered. An inconvenience is an adventure wrongly considered.
G. K. Chesterton
Henrythewound is offline
Old 09-06-2007, 08:36 PM   #2 (permalink)
I guess I should have mentioned this is going on a 2000 4wd 4runner, anyone know whether the diff drop spacers will fit on these (see pic). Steve mentioned some of the 2000 models have a different setup and the spacers included in the 7.1 won't fit.
[IMG][/IMG]
__________________
G. K. Chesterton
Old 09-06-2007, 09:10 PM   #3 (permalink)
xcmountain80's Avatar
Dunno till you try it.
Aaron
xcmountain80 is offline
Old 09-06-2007, 09:56 PM   #4 (permalink)
111db's Avatar
Send a message via MSN to 111db
Just looking at the pic I don't see why they wouldn't fit, as long as the new bolts supplied are long enough.
Yeah you will probably need to saw off the top of the rear shock. You can use a sawzall or a high speed cutting wheel (what I used). Do it as close to the bushings as possible - the chrome tube is actually hollow with compressed fluid inside. If you cut it too low you'll make quite a mess.
Not sure about the #7 kit, but with the #1 I had jackstands on the rear frame, and had the floor jack under one side of the axle full up... to install the opposite side spring.
Get all the shock bushings ahead of time. Steve sells them or you can get them from Toyota. I had problems getting all the right parts from Toyota - If I did it again I would just get them from Steve.
__________________
Jon
97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets
111db is offline
Old 09-06-2007, 10:30 PM   #5 (permalink)
Thanks Jon, I was under the impression I had everything I needed. I'm honestly not sure what a shock bushing is. I don't recall reading about it in the instructions but I am probably wrong. So it sounds like you essentially destroy the old shocks to get them off huh? I was hoping to salvage them to offer them to somebody on CL locally (free or nearly free).
EDIT: I believe the bushing is already on the shocks included in the 7.1 as shown on the SS site
__________________
G. K. Chesterton
Old 09-07-2007, 06:54 AM   #6 (permalink)
111db's Avatar
Verify with Steve but I believe the upper front shock bushings aren't included. I don't see them in the pic. The rears are all there. The upper front bushings are probably considered part of the topout plate, that is how their shown in the parts manual if I remember correctly.
As for the rear shocks, you might get lucky with an AZ truck that the bolts aren't all rusted up. Most people end up cutting them - I did.
__________________
Jon
111db is offline
Old 09-07-2007, 07:57 AM   #7 (permalink)
Rock Slide's Avatar
Joe,
Check out my bumper, lights/rack and lift writeup: http://www.yotatech.com/f2/installed...cluded-111728/
Scroll down a ways to get to the lift part of the write up. You can ready my experience w/ installing this lift. I've also got a few tips and "special notes" that might help ya.
__________________
2002 4Runner Sport 4WD
My 4Runner Profile
Accessories: SS 7.1 Lift Kit, WabFab 1" BL, TJM T15, Stubb Sliders, FX/TSX HID Projector Retrofit, 1st Gen Rollbar, Tundra Brake Upgrade, Hilux Surf Field Monitor, TRD Ivan Stewart Wheels, Nitto TG 265/75s, WeatherTechs, Hella HID 4000s, LED Tail Lights, JBL Speakers
Mods: Disabled DRLs, Disabled Keyless Entry Chirp, Disabled VTRAC/VSC/ABS, Fog Light Mod, Air Elbow Mod & Rear Diff Breather Mod
"Why fix a Jeep, when you can drive a Toyota?"
Rock Slide is offline
Old 09-07-2007, 10:15 AM   #8 (permalink)
Thanks very much to both of you! The one thing about the pic you linked (Jon) is that those are the old shocks that used to come w/ the system 7 setup, they are now the black heavy duty shocks. But you are right, I only verified that the rear shock had the bushing, I'll have to check on the front or just send Steve an email.
Rockslide I have seen your writeups before and they are always top notch, I'll be sure to consult the lift portion of yours.
Thanks!
__________________
G. K. Chesterton
Old 09-07-2007, 11:42 AM   #9 (permalink)
The rear shock bolt might not be rusted tight in AZ, but it is hard to get too. Using a small key on the nut you should be able to remove it by turning the shock (that is what I did). Does the front setup come preassembled?
__________________
Carsten
99 4runner SR5 4x4 5spd
Roadtripr is offline
Old 09-07-2007, 11:58 AM   #10 (permalink)
The front setup is not preassembled (if I understand your question). I have to remove the existing shocks and springs and use a spring comp to install the new ones. I have heard about this shock bolt before. I have also heard this can essentially ruin the old shock. Not a huge deal I just figured I would try to salvage as much as possible in case somebody can use the old parts (local craigslist).
Thx,
Joe
__________________
G. K. Chesterton
Old 09-07-2007, 01:04 PM   #11 (permalink)
thanks (I thought Steve sold the front set preassembled ).
The shocks are $30 new at the dealer so I don't know if you will make much on CL.
__________________
Carsten
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Which shops in Colorado install SS lift kits? RockyMtRunner 95.5-2004 Tacomas & 96-2002 4Runners 10 01-20-2007 05:57 PM
clutch install tips. DN1911 86-95 Trucks & 4Runners 2 07-10-2006 06:54 PM
SS brake line install Alin10123 95.5-2004 Tacomas & 96-2002 4Runners 14 02-11-2005 09:45 AM
93' Clutch Install Tips ? jsrusse11 95.5-2004 Tacomas & 96-2002 4Runners 1 04-20-2004 02:10 PM
Tips for TRD header install? robbieracer 95.5-2004 Tacomas & 96-2002 4Runners 13 03-06-2003 04:32 PM
2009 InternetBrands, Inc.
