Squeeling Noise Only When Wet - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-19-2007, 10:12 AM   #1
Any help greatly appreciated...
I've searched forum and could not find an exact answer to my problem... When I crank up my 4Runner after a rain, snow, morning dew (basically anything where the air is damp), or car wash I get a squeeling sound for a few seconds (probably no more than 10-20 sec). It doesn't happen in dry weather, just when its wet.
I don't think its the power steering because turning the steering wheel does not make the problem worse or better. Giving it a little gas after when it starts to make the noise makes it get louder, but goes away quicker (like its drying off the water).
I've looked at the belts and they seem pretty good, not dry rotting or anything. I'm wondering if the belt(s) are slipping...like there's not enough tension (Is there a way I can test this?). Others have mentioned to use/ not to use belt dressing...any pros or cons to this?
The car is still cover under the extended warrenty, so if its anything more than the belts I'm covered there. What is the normal mileage to put new belts on? I'm currently at ~65K. Any ideas?
Chris
Smokey is offline   Reply With Quote
Old 03-19-2007, 10:14 AM   #2
91TPU's Avatar
were the 02's equiped with a serpentine belt or the three belt system, if its three belts id put money on one of them being worn, or loose, and the moisture just makes it worse
91TPU is offline   Reply With Quote
Old 03-19-2007, 10:17 AM   #3
Kyle95sr5's Avatar
Quote:
x2. One of your belts is probably a little worn and the moisture is just making it worse.
Kyle95sr5 is offline   Reply With Quote
Old 03-19-2007, 10:41 AM   #4
mkgarrison5's Avatar
i have the same issue man. yours has 3 belts if i am not mistaken. you could replace them or tighten them. me, i leave them alone till it gets worse. i am trying to hold out for 100k miles so i can just replace them when i get my timing belt and waterpump and thermostat replaced. how often do you change these things?? lol
mkgarrison5 is offline   Reply With Quote
Old 03-19-2007, 11:11 AM   #5
BajaRunner's Avatar
Changing belts isn't all that bad. You should change them every 50k or so.
I haven't changed them on my truck but I know my PS squeels once in a while.
Usually all you need to do is to loosen the tensioning pulley, pull off the belt and retighten the pulley.
BajaRunner is offline   Reply With Quote
Old 03-19-2007, 11:14 AM   #6
does the engines with 3 belts have tension pulleys on all 3?? never changed one out on a yota.. only had jeeps with serpentine belts
Old 03-19-2007, 11:25 AM   #7
04 Rocko Taco's Avatar
I also was going to vote for Belts, but sounds like you got the answer already. As far as changing the belts, I dont know, I havent changed mine either...they are just barely strating to complain, I guess its about time...
04 Rocko Taco is offline   Reply With Quote
Old 03-19-2007, 11:33 AM   #8
Any good wite ups for the 3rd Gen
That's kinda what I was leaning towards myself. Do you guys know of a good write up on changing the accessory belts?
Thanks again,
Chris
Old 03-19-2007, 02:01 PM   #9
Beartracker's Avatar
Not to throw a hammer into the works so to speak but I have read on other sites where the squeling was caused from an idler pully going bad, Mike
Beartracker is offline   Reply With Quote
Old 03-19-2007, 02:02 PM   #10
Oh, way to complicate things Bear!!
I figure belts a preobably the cheaper easier swap, I would swap them first, then start to look at your pulleys...Thats just me though.
Old 03-20-2007, 02:11 PM   #11
wa4x4's Avatar
Mine does the same thing.
When I fire it up on some wet mornings it will squeak for 5-10 seconds, or when I go through enough water to slosh it over the front of the motor it does it too. I just call it wet belt noise, once they start squeaking more often replace them.
wa4x4 is offline   Reply With Quote
Old 03-20-2007, 02:22 PM   #12
etan's Avatar
i've had this problem twice before. once was just the fan belt was crapping out. the other was the pulley bearings were crapping out. either one or the other.....
etan is offline   Reply With Quote
90 pickup 3VZE rough idle, rattling... air noise problem zytra 86-95 Trucks & 4Runners 31 06-06-2016 10:50 AM
94 22re Strange Engine Noise (video!) Davebarbier 86-95 Trucks & 4Runners 32 11-03-2015 04:28 PM
Finally found you! New guy from CT Davebarbier Introductions & New Arrivals 12 10-02-2015 06:27 AM
mystery leak yay puddlepirate 84-85 Trucks & 4Runners 4 09-29-2015 09:02 PM
Questions- Housing & Diff install- 1989 2wd 8 inch where 1991 2wd 7-1/2 was Odin 86-95 Trucks & 4Runners 3 09-26-2015 07:56 PM
Tags
2005, 4runner, aquels, belt, cons, damp, dressing, noise, pros, sport, squeaks, sterring, toyota, wet, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
