Squeal When I turn the wheel
The colder the engine is the louder the squealing noise is when I turn the wheel. Also the RPMs rise maybe like 500. I checked the steering fluid and it is at the right level. Could the pump be dying or is this a normal thing? Also does the steering fluid ever need to be drained or is it a "keep-filling" kind of thing....
Thanks in advance....
It should be flushed and replaced many times in a vehicles lifespan, many don't and just continue to add fluid, not a great idea. It sounds like a loose/worn belt to me. It's loose if you can move it more than 1/4"-1/2", then just retighten. If it's cracked or fraying apart, replace asap. The pump may need rebuilt/replaced, if not.
rushw
07-18-2015 01:46 PM
Hamonacracker
07-17-2015 08:33 AM
skoti89
07-06-2015 07:45 PM
