| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
!!Speedy's Supercharger Thread!!
__________________
-Speedy Project SportRunner (240 RWHP 259 RWTQ) 2002 SR5 4x4 3.4L V6 TRD SC, URD 2.2" Pulley, URD 7th Injector Kit, Custom Gauges, TrueTrac, Tru Cool 4454 Tranny Cooler, Satoshi Grille, Fog Light Mod, DRL Mod, Sport Hood, TRD Wheels, ISR Mod, Deck Plate Mod, Supercharged badging Last edited by Speedy; 08-20-2009 at 12:32 PM. |
#2 (permalink) |
Subscribed! Look forward to more
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#3 (permalink) | |
Sponsoring Member
Quote:
The story of being able to choose on a scale from 1-10 is actually a myth.The only thing that they'll do if tweaked is to set it up for Soccer Mom's grocery getter which becomes a real soft shift, but yet doesn't slip. The shift I have isn't neck snapping, but it's got a good kick to it. You KNOW the tranny's locked up.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#4 (permalink) |
Subscribing Here.. Looking forward to it.
__________________
-Chris Tread Lightly! 04 Double Cab PreRunner. 3.4 - Auto 84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50 Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris Great Toyota Tech |
#5 (permalink) | |
Quote:
I've seen some posts that people had to put the tranny in "1" in stop and go traffic to keep from being bucked around during low throttle pressure shifts. I'd like to avoid that type of scenario personally.
__________________
-Speedy Project SportRunner (240 RWHP 259 RWTQ) 2002 SR5 4x4 3.4L V6 TRD SC, URD 2.2" Pulley, URD 7th Injector Kit, Custom Gauges, TrueTrac, Tru Cool 4454 Tranny Cooler, Satoshi Grille, Fog Light Mod, DRL Mod, Sport Hood, TRD Wheels, ISR Mod, Deck Plate Mod, Supercharged badging |
#6 (permalink) |
Is there any such thing as a nose drive support bracket for the 2nd Gen black SC? I was browsing Ebay and saw a SC for sale and the seller had something in there about a nose drive support bracket. I think searched here and saw some posts 2 or 3 years ago where Gadget was talking about having one made. I went to Gadget's site and the link where he talks about that no longer works.
So what's the story? Is it needed or ? http://cgi.ebay.com/ebaymotors/TRD-S...QQcmdZViewItem
__________________
#7 (permalink) |
Gadget originally thought there might be a weak link in the way the supercharger bolts down after TRD went to the self-adjusting tension pulley design. He modified the original pulley bracket design so he could keep that extra support but still use the new self-adjusting design. The original TRD design did supported the nose better, but removing the support hasn't really turned out to be a problem that I can tell. After all these years of those blowers in use I haven't heard of even one case where the supercharger has ripped out the mounting bolts from the intake manifold. I've even seen one guy that was running with a bolt or two missing and he didn't have a problem either.
BTW TRD does not sell those older style pulley brackets anymore so if you are really concerned about the SC support you'll have to fab one up yourself. Years ago Gadget had talked about having one made for URD to sell, but I suspect he decided there really wasn't a need for it, other than to calm the fears of us anal types.
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 04-02-2007 at 01:57 PM. |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) |
Subscribed.... i am near nashville, if you need any help give me a shout. I would love to see the whole process
#10 (permalink) | |
Quote:
__________________
#11 (permalink) | |
Sponsoring Member
Quote:
We cleaned 'em up and re-tapped them, but couldn't get enough meat to grip the bolt. I've gotta get a helicoil in there... so technically I'm running without any tension on that bolt right now.
__________________
#12 (permalink) |
I'm about to purchase the rest of my gauges. I'm going to use the Autometer Sport Comp series as they are reasonably priced and match the stock dash pretty well, and come with green bulb covers (again to match the dash). I really considered the Nexus gauges as they're VERY cool, but can't justify $600 in gauges.
In the Sport Comp series an electric boost gauge is available with a MAP sensor. It's about 4x the cost of the mechanical boost gauge at $179 from summit. Is this something that's really necessary or is a mechanical just fine? Electric with MAP http://store.summitracing.com/partde...5&autoview=sku Mechanical http://store.summitracing.com/partde...5&autoview=sku I'll be ordering a mechanical tranny temp gauge at the same time. There's an option to get an adapter to attach this tranny temp gauge to the hard line coming out of the tranny. Anyone gone that route? Seems you have to cut the hard line and splice this adapter in with included compression fittings. Anyone got other ideas? http://store.summitracing.com/partde...5&autoview=sku
__________________
#13 (permalink) | |
Sponsoring Member
Quote:
![]() In fact, $25 will get you a decent mechanical gauge... http://www.gaugepods.com/gaugegear.html I run a previous gauge that he offered and it's been fine. What're you doing about EGT?
__________________
#14 (permalink) |
Well I went with the mechanical boost gauge but used an electric temp gauge.
Here's my trans temp sender, its tapped into the rubber cooler line as close to the hard line as possible (before coolers):
__________________
#15 (permalink) | |
Quote:
__________________
#16 (permalink) |
Where'd that fitting come from? Custom job from hardware store parts? Also, why an electric tranny temp? I called Autometer to ask how the mechanical works, and they told me the line is filled with ether that moves the temp needle in the gauge and that no dangerous chemicals were routed to the cab.
__________________
-Speedy Project SportRunner (240 RWHP 259 RWTQ) 2002 SR5 4x4 3.4L V6 TRD SC, URD 2.2" Pulley, URD 7th Injector Kit, Custom Gauges, TrueTrac, Tru Cool 4454 Tranny Cooler, Satoshi Grille, Fog Light Mod, DRL Mod, Sport Hood, TRD Wheels, ISR Mod, Deck Plate Mod, Supercharged badging Last edited by Speedy; 04-03-2007 at 02:03 PM. |
#17 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. Last edited by mt_goat; 04-03-2007 at 02:05 PM. |
#18 (permalink) |
Yeah that's the Ace hardware custom job.
__________________
#19 (permalink) |
I'll go with the mechanical boost, but what do you mean you can't get a sensor after the SC? I took a look at the install docs for that electric boost gauge, and basically instead of the line going straight from the SC to the gauge, it goes through a MAP sensor first, then an electric connection to the gauge?
http://www.autometer.com/productPDF/0598A.pdf
__________________
#20 (permalink) | |
Sponsoring Member
I haven't put one in yet... When I said "cleaned up", I actually meant just "cleaned up". It looked like something had mashed down the top of the manifold and thus partially covered the hole. We cleaned that out, ran a tap through it and then test fit the bolt. Once we got the SC on, we couldn't grab enough meat with the bolt to really torque it down.
We actually had great luck using a helicoil elsewhere on the engine... I like 'em. ![]() Quote:
Ummm, I still wouldn't spend the money on the electronic gauge. If you're really itching to spend that much cash, then agree with my disagreeing with your tuner contact and put in an EGT.
__________________
#21 (permalink) |
So why electric on the tranny temp gauge over mechanical?
__________________
#22 (permalink) |
Sponsoring Member
Dale may have a different reason, but the last thing I want the possibility of leaking into the cab is 230* tranny fluid under pressure.
...same goes for oil pressure gauges.
__________________
#23 (permalink) |
There's no hot fluid going to the gauge. Autometer uses Ether in a capillary that goes to a bulb that's placed in contact with the fluid. The ether in the line moves the needle on the gauge. Worse case scenario you pinch the capillary and .0001 oz of Ether evaporate into the atmosphere. Knowing that does it change your opinion?
__________________
#24 (permalink) |
Sponsoring Member
Crap.. I'm 0 for 2 in here. Time to go back to work!
__________________
#25 (permalink) |
Gadget had mentioned something about not "running pressure lines into the cab" here: http://www.gadgetonline.com/Gauges.htm and I had probably heard some myth about smelling the oil through the line or something.
__________________
| Tags |
| 34l, ecu2, fuel, injectors, map, richer, supercharger, tacoma, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Speedy's DRL Switch | Speedy | The Classifieds GraveYard | 8 | 06-08-2007 04:00 PM |
| Speedy's Satoshi Grille Solution | Speedy | 95.5-2004 Tacomas & 96-2002 4Runners | 28 | 01-25-2007 06:53 PM |
| 9psi Supercharger pulley for TRD 3.4L Supercharger - brand new - | fireteacher | 95.5-2004 Tacomas & 96-2002 4Runners | 0 | 07-01-2006 11:50 AM |
| Please state your thread topic! Ambigious thread titles will be deleted w/o notice | Bob_98SR5 | Newbie Tech Section | 0 | 12-21-2005 02:24 PM |
