Specific Cylinder misfire - changes to random misfire
Old 08-07-2013, 01:37 PM
Yota Yeti's Avatar
Current odometer 216,xxx
Recently got the p0304 code. After thorough investigation (coil packs, wires, gaskets etc) the injector was the issue. p0304 code is cleared.
Immediately after the fix I drive around and a P0300 Random misfire code si thrown, that was not thrown before. I carefully pull everything apart and put it back together.
Now it runs still with a misfire, however no codes will show after driving around.
1800 rpm and 40mph is a happy place for then engine. It runs smooth as if there was no issue.
Thoughts advice ???????
Old 08-07-2013, 02:25 PM
Gsolo's Avatar
Engine? Vehicle?
I'm assuming 3.4 V6 in your 97 runner
Very first thing I would do is check grounds...at least one I can think of was unbolted to replace an injector
foampile
12-18-2022 01:29 PM
Sleaker
08-26-2020 06:03 AM
Marsheen
02-17-2016 12:29 PM
_Nicco_
08-28-2015 07:26 PM
256mbaker
07-31-2015 06:45 PM
Quick Reply: Specific Cylinder misfire - changes to random misfire
