Speaker Sizes in 3rd Gen.
Don't have the rig yet but I am picking out my system and am curious to know what size I can fit in the F/R doors and are there tweeters on the 96-97 SR5? Crutchfield lists 6 3/4 for the front only. TIA. -Stu.
In my 2001 4Runner I have 6.5" components with 1" tweeters on front, but I have only 5" in the rear.
When I tried 5.25" Infinity References, they didn't fit without the dremel tool ...
-- Andrey
-- Andrey
tweeters
I used pioneer 7/8(22mm) dome tweeters in my door when i blew out the stock ones. I bought them at Car Toys for $50. Install them yourself and save a bunch of money. Use the mountings from the stock one and not the new one its screws right in. The only problem was that they were a little thick and the cover for the tweeters had to be pucjed under the door panel.
Re: Speaker Sizes in 3rd Gen.
I found this link a while back that has sort of interesting info and a on dampening audible noise. The products seem a bit expensive but serve a designed purpose.
Q-->So does the 96 SR5 come with tweeters stock or not?! With my style of music it would be overkill to buy a component setup in the front with the highs being face level already.
I did read somewhere that Infinity Reference didn't fit (depth) too well. I have no problem using my dremmel to get a larger speaker in back. In fact I look for any excuse to use the dremmel like. . . cleaning my teeth and making a smoothie. 5.25 is tiny for a rear speaker. So. . .my choices for the rear doors are:
5.25 drop in (except hole modification)
6.5 (6.75 getting balsy) with some cutting and depth is going to be the deciding factor it seems from sschaefer3's page.
I will prolly cut the ish outta the rear door
later -Stu.
later -Stu.
later -Stu.
later -Stu.
justdifferentials
Just Differentials
08-30-2015 08:42 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
