Spark Plugs
Old 05-06-2006, 03:43 AM
SHICKS's Avatar
Spark Plugs
Hi Everyone.
It's a beutiful Saturday morning here in New Hampshire. I plan to replace my plugs on my 2002 4Runner with 3.4v6. It came with two different brands of plugs.
I went to the auto parts store and found 6 NGK BKR5EKB-11 for $6 each.
My question is can I use this brand and type on all 6 cylinders, or should I go to another store to find the DENSO brand for the other 3 cylinders?
Thanks in advance,
Steve
Old 05-06-2006, 06:08 AM
hupptoy's Avatar
You can use the NGK's in all 6 cylinders.
Old 05-06-2006, 07:10 AM
SHICKS's Avatar
All done, it took one hour start to finish.
She runs much better. I had 45k on the originals. It was not starting as fast and kind of felt sluggish, but I am sure that is all in my head.
Thanks
Steve
Old 05-06-2006, 07:29 AM
fireteacher's Avatar
did you check the gaps on them?
Old 05-06-2006, 07:46 AM
jrallan26's Avatar
I need to do the same. Was it tough?
Old 05-06-2006, 01:32 PM
SHICKS's Avatar
Nope, not at all. A few tips. Tape your socket to the extension, I learned that really fast. The passenger side is easier than the drivers, even though you have to remove the intake tube. Other than that, it took me about an hour including running in the house a few times.
Steve
Old 05-06-2006, 07:27 PM
jtmaxx7's Avatar
I changed mine at 60k. It runs a lot smoother now. Oh yeah all NGK's and gapped prior to installing. Supposed to be .043, however all but one was at about .040. Someone said just install. I don't think 3 hundredths of an in makes a diff.
Old 05-06-2006, 07:34 PM
Tanto's Avatar
They should all be gapped the same.
Old 05-06-2006, 07:46 PM
rimpainter.com's Avatar
^ yep, and you need to use a wire-feeler type guage to do it right. Mine were way off when I got them.
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
raptor510
08-19-2015 02:15 PM
accuracy
08-04-2015 08:05 PM
defrag4
07-31-2015 10:50 AM
Quick Reply: Spark Plugs
