spark plugs
Old 04-19-2004, 09:51 PM
MY024runner's Avatar
spark plugs
HI everyone. I Had a ? about the spark plugs. I have a 2002 v-6 4runner 5vzfe. I was going to change my spark plugs but see that the other side is I am guessing direct ignition ? I was wondering what do I do unscrew the screw then pull out the plugs to put new plugs in? Has anyone haD experience with changing the sparkl plugs for this engine and have any tips since it pretty tight to do any work of changing the spark plugs. Thanks in advance
Old 04-20-2004, 12:50 AM
3.4Runner's Avatar
Its pretty easy to do the plugs. The ignition coils on the passenger side come right out, just remove the screw on the coil (little grey boxes) and the wire harness and they slides right out, the spark plug will be located below. It will be easier to remove part of your air intake (the flexible rubber tubing and intake silencer that connects the airbox to the throttle body) to give you some space to work. You'll need a pretty decent extension (about 12") for your socket to get at a couple plugs on the driver's side (unless you plan on removing the intake manifold).
This would be a good time to clean your throttle body and air intake as well.
Make sure you use antiseize and torque the new plugs down to proper specs.
BTW, if the plugs are being changed for the first time you'll have different plugs on the different banks (NGK on one side, and Denso on the other)--you can use one brand when you replace all 6.
Old 04-20-2004, 01:06 AM
Thanks for the replie back also for the tips
Old 04-20-2004, 01:32 AM
jimbo74's Avatar
for my older 22r, NGK V-Power as opposed to the regular NGK plugs was specified by toyota as factory replacement... as were ND plugs were also acceptable
Old 04-20-2004, 08:04 AM
thanks for the tip
Old 04-20-2004, 10:19 AM
Do you know if I have to dissconnect the negative batterry in order to get to change the spark plugs? Thanks in advance
Old 04-20-2004, 10:31 AM
rimpainter.com's Avatar
You dont have to, but its never a bad idea.
Old 04-20-2004, 11:02 AM
MTL_4runner's Avatar
I don't, but make sure the key is no where near the ignition!
Old 04-20-2004, 07:13 PM
Ok thanks fellas for the tips
Old 04-21-2004, 12:19 AM
I forgot to ask I bought factory denso's. Dealer tells me they are pre gapped at and autozone sells them and they say I need to gap them. Which one would be correct?
Old 04-21-2004, 03:34 AM
The OEM Densos do come gapped properly.....
......Autozone may say to gap all plugs to cover their a$$.
Before putting in each plug, check the electrode for damage against another good plug.
Any damage will be very obvious if you hold it next to another plug.
Old 04-21-2004, 09:36 AM
Mtl 4runner Thanksfor the reply and tips
montanatruck
02-26-2017 07:07 AM
raptor510
02-17-2017 07:11 AM
raptor510
08-19-2015 02:15 PM
accuracy
08-04-2015 08:05 PM
defrag4
07-31-2015 10:50 AM
Quick Reply: spark plugs
