Spark plug wire replacement on 3rd gen. - Help
Old 02-28-2003, 04:01 AM
wayne's runner's Avatar
Question Spark plug wire replacement on 3rd gen. - Help
I'm going to replace my original spark plug wires with a new set of NGK's (TE66 blue wire set). I looked over the OEM setup and noticed that there is a plastic retainer cap holding the spark wire to the coil pack on the passenger side plugs. What is the trick to getting this plastic retainer cap off so that I can remove the old plug wires? I did'nt want to damage them by pulling/prying on them the wrong way since the pastic caps need to be reused.
Old 02-28-2003, 06:26 AM
FattyCBR's Avatar
There is a little clip on the retainer cap. It's on the opposite side of where the wire comes in. You can use a little screw driver to open it while you pull up on the cap.
Old 02-28-2003, 06:45 AM
Bob K's Avatar
I put the same wires on mine about a month ago, the clip pops out real easy, I took me about 15 minutes to do it and most of that time was removing the intake silencer to get to the coil packs. Just don't force anyththing, I found it easier to remove the screw that holds the coil pack down pulling it off and changing it that way.
Old 02-28-2003, 07:30 AM
Ryd
Ryd's Avatar
Why change plug wires?
Bad wires, or just getting old? I didn't think new wires did much but change aesthetics...
Ryd
Old 02-28-2003, 09:47 AM
Smile
Thanks for the replies guys. I've got 80K miles on my 97 4runner (3.4L) and 26K miles on my spark plugs. Lately, it seems like I have to crank 1-2 seconds longer to start it when cold. So I felt it was time to put new plugs in and while I'm at it, put in new plug wires as a cheap PM/tuneup ($35 for wires, $10 for K16TR11 plugs). My last car was a 1986 Honda Accord (4 cyl) and I replaced the spark plug wires at 100K and it definitely made an improvement in performance (easier starting, more pep, and a little increase in MPG). There seems to be no recommended time/mileage as to when to replace plug wires - most people seem to wait until they notice a major decrease in engine performance.
Old 02-28-2003, 10:02 AM
Ryd
Ryd's Avatar
Anybody else have thoughts?
Other plug wire choices? Other pricing info?
Old 02-28-2003, 10:35 AM
Ryd
Ryd's Avatar
Right on!
Wayne,
Please keep us posted on any perf. or mileage changes you notice. With the cost of gas go up, every mile counts. Plus, I have at least 30k on my plugs now, and I'm still running with original wires. I guess $35 for NGK wires isn't too bad. Where'd you get'em?
Thanks,
Ryd
Old 02-28-2003, 05:38 PM
nis240sxt's Avatar
You can get the wires at autotoyotaparts.com. I'm noticed something weird on 3rd gen 4runners. I pulled the plugs today and noticed the spark plug wires on the drivers side were out of sequence. They read 3, 1, and then 5 from the back. Is this normal? Anybody??
Old 03-01-2003, 04:08 AM
Bob K's Avatar
That is the way they are for what ever reason. It had me stumped too for a moment when I changed mine.
I did the plugs and wires on mine at 34K NGK plugs from the dealer and the NGK blue wires. I noticed an improvement in the starting and what seems to be a little better response. Fuel economy improved about 1-2 MPG.
06-01-2021 01:51 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
toyota32
07-06-2015 05:42 PM
colinmil
07-06-2015 04:03 PM
elwood73
07-05-2015 07:07 AM
Quick Reply: Spark plug wire replacement on 3rd gen. - Help
