Spacers & OME Springs?
Old 03-21-2003, 10:14 PM
HBoss's Avatar
Hey all,
Need your expertise/opinion.
1. With a 2" confed spacer lift, should I be immediately concerned with CV angles, balljoints or extensions on anything like a body lift (I.E. brake line, transmission, etc.)?
2. With 2" cornfeds up front, should I go with OME springs in the rear or 2" spacers?
3. If I go with OME springs in the rear should I get the MD or HD ones? I don't tow. I don't haul. I do offroad and I don't like a stiff ride.
4. How much lift would you normally get out of the MD OME & HD OME springs?
Thanks for any advice.
Al
Old 03-22-2003, 10:48 AM
White SR5's Avatar
Input
This is from what I 've found. OME's are innately extermely soft -- the softest out there. HD is still an improvement over stock, and MD's are like soft coils from most other brands. Adding a 2" spacer wouldn't kill CV angles, but it will put a tiny bit more strain on them. I'd reccomend going with OME HD's in the rear (OME 891) because you don't feel the bumps as much in the rear, and then OME MD's in the front (OME881). If you go with that set-up and add 33" tires, you'll probably gain about 2.5-3 inches with only the new coils, and then 1 or 2 more with the bigger tires. I'm going to do an OME and SAW lift sometime (when the wallet is bigger...) and frommy research that's what I can tell you.
Zach
Old 03-22-2003, 11:34 AM
HBoss's Avatar
Thx for the reply man. I'd love to have SAWs & OMEs right off the bat, but I just don't have the cash for it now.
I think I've decided to go w/2" cornfeds & stock springs in the front w/OME 890s (MD) in the rear. I don't want too stiff a ride, even if it is in the rear and I think it will look more level this way. Unfortunately the spacers will stiffen up my front ride, but hopefully not too much.
I think my butt would be too high w/2" spacers up front & 891s in the rear. Please feel free to correct me if I'm wrong here.
I saw a pic of the 891s and they look like bigger PP springs. They look like they are progressive, which should smooth out the ride, give me lift and decent flex. I've read too many posts now, by ppl who say the HDs made the ride too stiff.
Thoughts?
Old 03-22-2003, 04:08 PM
BigJohn's Avatar
I am going to go with this OME880/N91SC up front
OME890/N86C for the back all ome springs and shocks the front will sag even the hd do so a 2 inch spacer will fix this dont know how high this is gonna be lol i hope i can fit my 33's, i be really mad if it did not
1.5" or 2" front spacer
BigJohn's Avatar
Thoughts?
hey buddy you gonna get 33's
Old 03-22-2003, 08:20 PM
HBoss's Avatar
For sure, but I just bought these BFG ATs last year. I gotta run 'em into the ground so I can buy new 33" mudders.
nvwiggins
13
06-16-2016 03:05 PM
Scottcrb
03-03-2016 11:57 AM
jaretstuff
10-22-2015 05:25 PM
Swampwalker
10-12-2015 09:49 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: Spacers & OME Springs?
