Soon to test....5vz-fe revvved up!
Old 05-06-2006, 10:08 AM
Weasy2k's Avatar
Well time is counting to my deadline of pushing the 5vz-fe beyond is 5500rpm redline and deep into 7000-7500rpm range.
Phase 1 Specs:
133,000mile engine
High Volume Oil pump with new toyota water pump
Stock Bottom end (besides what listed above)
Head work-
3angle valve job
S2S 80lbs 5vz valve springs
S2S 272deg N/A Cams
S2S Installed and Tuned Perfect Power XMS Standalone
Some basic mods to help the head flow better have been done, during phase 2 (this fall) the entire engine will be reworked to allow the 5vz to spin at the 9,000rpm goal.
Here are pictures:
(messy shop.... )
That is the N/A engine going into my MR2 by the end of the month....
Then starts:
Engine 2 Specs: (soon to be for now it sleeps)
Same head upgrades minus the valve job and S2S 272 Turbo Cams vs N/A cams.
Garett 60-1 Turbo set a 13psi for the year
44mm Tial Wastegate
Node/MR2 Guru Manifold & Downpipe
This engine will rev to 6500rpm vs the 7500rpm on the other engine (added stress of the turbo plus the rpm on a stock bottom end could lead to not so good results )
So you can see we are busy busy busy here Testing new waters for the 5vz.
Going to be a FUNNNNN summer! I cant wait to hear those engines fire up and rev that high.
Old 05-06-2006, 11:15 AM
rimpainter.com's Avatar
...and you better post some vids (with sound) when you get these going!
Old 05-06-2006, 11:32 AM
HOJU's Avatar
Can't wait!
Old 05-06-2006, 01:11 PM
Weasy2k's Avatar
i cant wait too
To bad i am full of work here and am slowly doing everything at once.
I will have lots of footage up when the cars start.
You can follow the progress on my website of the turbo engine build. I iwll start the gallery soon
Old 05-06-2006, 02:44 PM
Greedy's Avatar
Holy crap... I want to come up and see when you get those things fired up!!!
Old 05-06-2006, 03:48 PM
bigacuralvr's Avatar
I'll take the MR2's in the background, or just a fully built 3SGTE for my AllTrac please.
Old 05-06-2006, 04:47 PM
Weasy2k's Avatar
Which one?
The yellow and red (to the right of yellow) mr2's will be going through washington to medford in late July...
If they both pass my testing on the soon to be inshop dyno + 400km "test cruise"
Old 05-06-2006, 06:09 PM
914runner's Avatar
You moving to medford?
Old 05-06-2006, 07:20 PM
Weasy2k's Avatar
no no
there is a large mr2 meet going on down there
Old 05-07-2006, 12:21 AM
914runner's Avatar
Oh.
So what ECU's do you run on your 5VZ-FE swaps into MR2's?
Are you going to run the Supra MAF on that N/A motor?
Old 05-07-2006, 10:06 AM
wow!! you're doing the 5vzfe into the MR2?? I heard of this, but never seen it!! BTW, what did you do with the 3sgte's? or were the all 5sfe's? Im jealous.
Old 05-07-2006, 05:13 PM
Weasy2k's Avatar
I am running our Perfect Power Standalone units which makes it possible to cross the redline marker that the stock ecu prevents.
These standalones will soon be plug and play compatible with the 5vz.
The N/A Motor will actually run with no maf instead it will be a MAP sensor.
Yea the 5vz has been done (to the point of started) once before and he is about to finish his second one. There are several other 5vz swaps in the process as well including mine and my customers.
The 3s from my engine was sold and the 5s from customer engine is going on the selling block too.
Old 05-07-2006, 05:17 PM
914runner's Avatar
What injectors are you going to run on that N/A motor?
Old 05-07-2006, 06:22 PM
Weasy2k's Avatar
stockers....
if they cant do the task I will put in the Supra ones...
Im sure they will be jsut fine considering it can handle the airflow of the s/c at 7psi which is = to a lot more airflow then a n/a pump will do.
I will have LOTS of gauges monitering the block oil pressure, temp, fuel pressure, afr (duhh), EGT in both banks.
To name a couple..
Once i get a good and stable tune i will remove most of them .
THe ecu will be setup to read the sensors that i put on the block and quickly jump into limp mode if something is not right. I will even go as far as set it up so during colder engine temps the engine cant rev it passed a certain rpm and as it warms up the redline grows.
Old 05-08-2006, 03:21 AM
manofsteele2003's Avatar
Damn, makes me miss my MR2. I sold my 91 SMG Turbo to buy my 97 SR5 4Runner. Oh well, I still have at least one sports car left.
Old 05-08-2006, 11:43 PM
Weasy2k's Avatar
yea im happy i kept my tacoma...nothing will make me get rid of her...
Old 05-09-2006, 11:54 AM
99_Runner's Avatar
I can't wait.
Old 05-10-2006, 08:38 AM
kevin444's Avatar
good shizzle. thats probably almost sounds like an f1 car haha.
Old 05-10-2006, 10:40 AM
Weasy2k's Avatar
haha once i get stage 2 & 3 done it will....
Imgaine the 5vz with ITB's god damn its going to be beautiful
Quick Reply: Soon to test....5vz-fe revvved up!
