Sonoran Steel Pan Hard Drop Bracket Install?
Old 10-08-2004, 12:06 AM
Bigkahuna808's Avatar
I got this pan hard drop bracket from Steve in the mail today and can't wait to install it . But I hit a little "Snafu"/ problome . IM trying to figure out the bushing order as it goes on the lower bolt. This is what I got in the configuration, I just want to make sure I got the correct order. (bolt head)(washer)(bracket)(thin washer)(washer)(bar)(washer)(washer)(bracket)(wash er)(nut) Hopefully this is the correct order . If not can someone draw it out for me. I can't really follow the directions provided about the washer placement. thanks for the help guys, I really wish I could get a better mental picture to put it on my self, but No luck. So please help me out guys, and if Steve if your able to give me some tips even though your in Moab.
Thanks, Aloha, and
Old 10-08-2004, 09:30 AM
comon guys, I know people out here are running the bracket, i need help so I can install it properly. Thanks guys
Old 10-08-2004, 06:20 PM
payyourtoll's Avatar
it almost sounds like you are talking about the diff drop, not the panhard
Old 10-09-2004, 01:05 AM
No its the Pan Hard drop bracket in the rear. I don't have the need for a diff drip up front. Im in the 2wd catagory. But hopefully someone can post the washer order so I can get this ting installed. thanks
Old 10-09-2004, 01:36 AM
anthony1's Avatar
You could try emailing Steve.......
Old 10-09-2004, 01:44 AM
I did but he is In Moab, I wanted to get it on today. But oh well, might as well wait for the expert? He get back from the mother land of offroading on the 10th
Old 10-10-2004, 12:19 PM
Bump to the top, need some help here guys.
Old 10-10-2004, 12:51 PM
4Crawler's Avatar
When I helped to install one, we just put in the washers and spacers as needed to fit the panhard bar end into the wider than stock bracket. Don't recall the exact order, but it did not seem to be that much of an issue.
Old 10-10-2004, 02:28 PM
Thanks roger
06-01-2021 01:51 PM
nick9455649
09-11-2015 05:10 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
Jnkml
07-06-2015 01:20 PM
Quick Reply: Sonoran Steel Pan Hard Drop Bracket Install?
