So if 99s and 2000s have taller springs then...
Old 03-02-2006, 06:26 AM
Gerdo's Avatar
So if 99s and 2000s have taller springs then does a spring lift (TRD or OME) not lift as much as on a 97?
Old 03-02-2006, 06:32 AM
MTL_4runner's Avatar
No, they all would lift about the same, the 99s will just sit about 1" higher in stock form.
Old 03-02-2006, 06:34 AM
ebelen1's Avatar
Jamie, I think the answer is yes as the '99 was already taller. The new lift will get the '97 and '99 to the same height so the lift will provide less to a '99.
Old 03-02-2006, 07:11 AM
Yes, you are correct and I thought I was saying basically the same thing, but maybe I misunderstood the question.
I was referring to the final lift height of all after any swapping.
Old 03-02-2006, 07:57 AM
Gerdo's Avatar
So, both the front and rear on a 2000 are stock about one inch higher. My concern was that the 2000 had a longer spring on the front to compensate for weight and the rears are all the same. I dont want to install new springs, OME 881-890 and find that the 1.75" in front only gives me .75" and the rears still give me 2.5".
Old 03-02-2006, 08:23 AM
All the spring perches/mounts are in the same location on all 3rd gen 4runners (which is what I think you were trying to ask in the first place). Thus any swaps of springs should show similar final height results across all years. I did the same setup you're mentioning and you will likely get similar results (maybe +/- 0.25"). The only reason the 99s were any different height was because the springs were different, nothing else.
Old 03-02-2006, 02:39 PM
Gerdo's Avatar
I know that the 2000 has a taller front spring (9 coil spring) but did not know if the backs were taller to match.
Old 03-02-2006, 11:46 PM
Gt4r97's Avatar
If I replace my 4Rnr 97 spring with 99 spring will this give me a 1" lift or not?
Old 03-02-2006, 11:50 PM
grimpy's Avatar
my early build 3/00 limited 4wd didn't come with the longer coils...
Old 03-03-2006, 04:00 AM
pat161's Avatar
My 2000 also does not have the longer coils. When parked next to a 99 the 99 is clearly higher.
Old 03-03-2006, 04:03 AM
Originally Posted by Gt4r97
If I replace my 4Rnr 97 springs with 99 springs all around, will this give me a 1" lift or not?
Yes, it should give you roughly one inch of lift.
justdifferentials
14
06-11-2017 08:36 PM
punks_is_4x4
05-31-2016 06:03 AM
RickyD
10-02-2015 07:53 AM
potatopants
09-15-2015 06:26 AM
justdifferentials
09-05-2015 06:52 PM
Quick Reply: So if 99s and 2000s have taller springs then...
