Smell of burnt oil....
Old 12-02-2003, 03:41 PM
SaiSokuRunner's Avatar
Hey guys! New to the site, my names David...have a 94 4Runner. I tried to do a search (found nothing) to resolve a problem that I can't seem to fix w/ my 4Run, and I'm curious to see if anyone else has experienced this problem.
There is an overwhelming smell of fuel when the 4Run is parked after being driven for a bit. I don't notice it just after I park, but when I return to get back into it. The odor has started to turn into something more like a burnt, crude, like oil/fuel smell...anyone got any clue?
Old 12-02-2003, 04:34 PM
ByThaBay's Avatar
it could be that you need to replace your charcoal canister. this device captures stray fuel fumes from the gas tank. I've heard that when these fail people experience similar symptoms to what you're experiencing.
ofcourse keep it simple first, and check all other things before replacing anything.
Old 12-02-2003, 06:25 PM
Poul D'eau's Avatar
I had the same problem recently. I had some oil leaking out of my driver side valve cover because the bolts are loose. after torking them to spec. no more problem.
Old 12-02-2003, 10:59 PM
Thanks guys, I appreciate the feed back. I thought of the charcoal canister tonight, so I will definately take a look at that in the morning.
I should also double check, again, to see if I have any oil that could be possibly be leaking out and burning off the motor. I haven't seen any, but I could be not looking hard enough...heh.
Please keep your feedbacks coming, just in case there could be some other possible complication...
Old 12-03-2003, 06:05 AM
CTB
CTB's Avatar
Just out of curiosity, what are the torque specs for the valve cover bolts on a 3.0L?
Old 12-03-2003, 07:10 PM
Poul D'eau's Avatar
Three step process:
Step 1: torque to 33 ft-lbs
step 2: turn 1/4 turn
step 3: turn 1/4 turn
Page 81-82 in haynes
Haynes calls it a cylinder head cover.
Old 12-04-2003, 05:03 AM
CTB
CTB's Avatar
Three step process:
Cool, thanks for the info. I will have to check them out when I get home and have a torque wrench.
Steven.m.paulk
06-07-2020 10:45 AM
puddlepirate
07-30-2016 06:29 PM
IntoTheVoid
10-24-2015 04:54 PM
Ott47
09-14-2015 12:09 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Smell of burnt oil....
