small coolant leak by the top radiator hose going to the engine
Old 10-13-2009, 04:08 PM
sis004runner's Avatar
i replaced the hose could this mean its the thermostat houseing that is leaking
Old 10-13-2009, 08:57 PM
rjaudi's Avatar
The thermostat housing connects to the lower cooling pipe. There is a gasket under the water outlet that the upper hose connects to at the engine. It is a 4 dollar part so it may be worth looking into.
Old 10-13-2009, 09:11 PM
is t a pain to do?
Old 10-13-2009, 10:26 PM
raydouble's Avatar
What engine?
Got pics of the leak?
Old 10-13-2009, 10:28 PM
3.4 theres a puddle on the timing cover sittng below the hose gets on the belt and squeeks
Old 10-14-2009, 07:17 AM
Kerby J's Avatar
well fsm recomends that if collant gets on your timing belt that it should be replaced jus fyi
Old 10-14-2009, 10:51 AM
not the timing belt the drive belts its a really slow leak
Old 10-14-2009, 11:49 AM
brian2sun's Avatar
I would do a pressure test and see if you can tell where it's squirting out from. Maybe the hose fitting on the top of the engine where the top hose connects. There are 3 bolts that hold the fitting on if I remember right which if loose/corroded can cause a leak.
Spicer
06-10-2020 08:39 PM
voiddweller
19
05-02-2016 09:10 PM
noahstancik
07-10-2015 11:18 AM
Mutinebullfrog
06-18-2015 01:36 PM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: small coolant leak by the top radiator hose going to the engine
