| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Sirius Satellite radio mounting suggestions needed
__________________
'97 4Runner SR5 4X4, Anthracite Grey - Factory Brush Guard w/mounted Hella 500s, Pilot Fogs, Kenwood Head Unit, Sirius Satellite Radio, Footwell Lighting, Lund Hood Deflector, Dueler AT Revos - 169,000 mi (03/23/07) '07 Toyota Camry SE I4, Super White |
#2 (permalink) |
If you don't use your ash tray, then mount it in that pocket under it.
__________________
-Travis 1997 4Runner SR5 V6 4X4 Supercharged Desert Dune SOLD :( 1992 Celica All Trac (AWD-Turbo) #223 of 271 US spec for 1992 FOR SALE 2005 Tundra Double Cab Limited 4X4 2.5" lift 265/70R17 Dueler Revo's 4Runner and Celica Webpage |
#3 (permalink) | |
Quote:
__________________
#4 (permalink) |
Go to home depot and look for some "L" brackets, then you can glue of mount it to the panel.
__________________
#5 (permalink) |
my set up
This is what I did with mine .... hope it helps. EDIT: someone please let me know if the link works, I can never get it to work right.
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards. <-- the artist formerly known as sdastg1 Last edited by sdastg1; 12-26-2003 at 05:44 AM. |
#6 (permalink) | |
Quote:
Sirius Audiovox SIR-CK1 Shuttle
__________________
#7 (permalink) |
sorry I thought it was the same kenwood as mine, didn't pay attention to the model number.
The only suggestion I have for you is mount it at eye level, or at an angle where you can read the screen easily. Also a place where you can easily reach the buttons, b/c those things are so damn small. Other then that, take pics and show us what it looks like EDIT: I just noticed your in chicagoland, where abouts?
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards. <-- the artist formerly known as sdastg1 Last edited by sdastg1; 12-26-2003 at 06:09 AM. |
#8 (permalink) | |
Quote:
__________________
#9 (permalink) | |
Quote:
__________________
#10 (permalink) |
SLC Punk:
I noticed a post of yours on the backstage Sirius forum where you posted a pic of your roof mount antenna. I was thinking of putting the antenna in the same place originally, but I could'nt get the wire to fit snug enough to stay in place. It seems that there was too much space around the window. How did you get your wire to stay put?
__________________
#11 (permalink) |
SLC Punk:
How did you run your power? What did you tap into? Did you buy an aftermarket adapter wire? Did you use an in-line fuse?
__________________
#12 (permalink) | |
Quote:
runner4: I used to live on N. Lake Shore Dr., I just moved about a month and half ago to Md.
__________________
Experience is a hard teacher because she gives the test first, and the lesson afterwards. <-- the artist formerly known as sdastg1 |
#13 (permalink) |
mine is built into the radio and the reciever box is under the dash. I mounted the ant on the dash . it works pretty good. I had it on the outside but the truck looked realy bad.
__________________
TRD Supercharger,TRD 7th injector,URD AIC ,Headers,2.5 Magnaflow exhaust,Airfilter,air box mod,flexalite 210 fans,optima yellow top,Warbro 190 ,TRD t stat,ramsey 8000 winch and rear locker mod |
#14 (permalink) |
SLC Punk:
__________________
#15 (permalink) | |
Quote:
Probably doesn't make sense, but if you look at your window molding you will understand.
__________________
#16 (permalink) | |
Quote:
![]() I used one of those fuse tap's and have it fused through there.
__________________
#17 (permalink) |
I'll have to look at the windshield. Right now my antenna is on the rear roof, and comes in through the rear hatch. I'd rather move it to the front. Thanks.
__________________
#18 (permalink) |
I installed it that way at first. But when I opened my rear hatch all the way, the hatch was pressing on the cable. I was afraid that it would short it out. So that's why I moved it to the front.
Do you have the Terk 3 antenna?
__________________
#19 (permalink) |
Yes, I have the Terk3, but the wire doesn't seem to be getting pressed when the hatch is fully open. I would still rather have it in the front anyways.
__________________
#20 (permalink) |
Sponsoring Member
Runner4;
I have the Delphi receiver for XM radio which is about the same shape/size of the Shuttle. I don't have a dedicated picture of where it ended up, but you can see it in this shot: http://www.midiwall.com/4Runner/dirt..._Reiter_13.jpg Basically, it's sitting just in front of the transfer case lever.
__________________
~ Mark '96 4Runner Limited S/C MI - 370cc injectors, Air! horns, Airaid MIT, ATS A-arms, 285/75/R16 BFG MTs, Bored TB, Brembo slotted, Cobra 75 WXST, Deckplate, Downey headers, Hayden cooler, IPT valve body, Level 10 torque convertor, Meanstreak exhaust, OME/OME rears, On-board PC (XM, Nav, WiFi, etc), Port 'n Polish, Remote Start, SAW fronts, Hilux console, SMT-5, Stubb's sliders, Supra MAF, TJM-17, 2.0" pulley, Viair 450c, Walbro 190, Weasy2k cams |
#21 (permalink) | |
Quote:
__________________
#22 (permalink) |
I have the XM Delphi radio, but that Audiovox radio is basically the same size and shape as mine, so I assume it mounts the same.
I bought an ultimount and mounted it flat on the bottom of the hump under the ashtray. pics are at http://gallery.zemudaville.com/XMBaby%21 Bill
__________________
My name is BILL not Bob Mazda3 :0( Last edited by bobzemuda; 12-27-2003 at 09:32 PM. |
#23 (permalink) | |
Quote:
I put them on either side of cable and secured them with a dab of silicone glue. Now I have no worries, and I prefer this mounting location. Bill
__________________
My name is BILL not Bob Mazda3 :0( |
#24 (permalink) |
i'm planning on finding and fabbing a goosneck type mount. so i can move it out of the way when not needed.
btw, i just found www.siriusbackstage.com for my sirius forum needs. for my xm tuner, that is much simpler since it uses the sony unilink bus and i just mount the sucker back in the amp rack out of the way...
__________________
leo d. stock 90 4runner |
#25 (permalink) | |
Quote:
Oh well it works and I don't want to mess with it anymore.
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Sirius Xact XTR3 Visor Satellite Radio w/home & car kit. BRAND NEW!!! | mattk | The Classifieds GraveYard | 3 | 02-24-2007 04:03 AM |
| Ham Radio and Satellite Radio | kvanderploeg | GPS & Communication | 5 | 04-20-2006 02:03 PM |
| XTR8CK Sirius Satellite Plug & Play Radio Receiver and Vehicle Kit | lee | Vehicle Audio & Home Entertainment | 2 | 12-27-2005 08:26 AM |
| Sirius Satellite Radio Problem | LSUMatt1514 | Vehicle Audio & Home Entertainment | 3 | 08-12-2004 11:21 AM |
| Pics of my Sirius Satellite radio!! | SLC Punk | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-25-2003 11:33 AM |
