Simple spark plug wire
Simple spark plug wire question
Good day - I went to Kragen yesterday to purchase a new set of spark plug wires, and it only comes with as a set of 3 wires? I was a little bit baffled (1st replacement for my 3rd gen 4runner). I replaced my plugs approx 20K ago, so they should be clean.
Does the ignition coil side have to be replaced as well? Or do I simply replace the 3 wires on the "non-coil" side?
Also, I recently failed smog, so I wanted to know if replacing my wires as part of tune-up will actually help me pass my smog? I've seafoam-ed the hell out of my system, thx to some threads here @ Yotatech.
Thx!
Thx!
take them back!
it sounds to me like some one took the other 3 wires and the coil wire out of the pack, if you have a V6 there should be 6 wires, and if its a 3.0 a coil wire.... I say take them back and let them know...
Kevin - Thx for responding. I did some research online, and it looks like they sell the coiled wires seperately? However, Kragens & Napa only sells the "non-coiled" wires? Do you know if I need to replace the coiled wires. I would assume yes I would have to...
montanatruck
02-26-2017 07:07 AM
88runnergomas
07-09-2015 01:12 PM
