| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Co-Founder/Administrator
Staff
Which silicone for firewall grommets
__________________
Corey 2007 FJ Cruiser Built for 4wheelin', expedition, camping, and overlanding use PNW FJ Cruisers ☺ Detailing 101 ☺ Join Topsites ☺ Muffler Comparisons ☺ Maggiolinas In The Wild FJ Cruiser Buildup ☺ New Roof Top Tent ☺ Video Of My Penthouse Part II ☺ Rehinge Your ARB/Engel Fridge Blog About Roof Top Tents ☺ FJC Magazines Online Review Of My Tent ☺ 2009 Specialized Rockhopper Pro |
#2 (permalink) |
RTV works well!
Corey,
I have used the Kragen's special RTV black silicone sealant with plenty of success (blue packaging). It's easy to apply and lasts a while and a tube of it is about 3-4 bucks. It's fairly flexible - but definitely protects against water and holds up well to road grime. Since my rig is a 2WD - i don't have to hose off the undercarriage too much - so hopefully someone else can chime in in case there is something better. RTV also has a black rubber sealant which looks interesting but is about twice as much. It's supposed to be more flexible, but I don't plan on putting more holes in the firewall anytime soon. My cable running has been due to audio cabling, but should suffice for your application. I coupled the sealant with the plastic split-loom tubing to deflect water from running down the cables as much as possible. Hope this helps! Pete
__________________
1994 4Runner SR5 2WD V6 auto Tires: 225/75 R15 Michelin LTX (next to upgrade) Sound: Alpine, JBL speakers, Blaupunkt amps and Boston Acoustics subs (along with Dynamat) Security: Clifford alarm NEW: Downey HD/Bilstein & window tinting |
#3 (permalink) |
I would just get a tube of the regular household silicone that's used to seal up windows. That way you'll know it'll be waterproof. I'm not sure if it'll stick to metal or plastic though, so check that out.
__________________
-Chris If you can't explain it simply, you don't understand it well enough. Click here to search! My Website |
#4 (permalink) |
I used sensor safe silicone just because it's what I had lying around and it's held up fine so far.
__________________
Milan _ _ _ _ _ __ _ _ _ _ _ _ Support our troops! '98 4R Limited '82 Toy 4.3, SM465, D20 <- Sold |
#5 (permalink) |
two words:shoe goo
__________________
1997 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1998 Toyota 4Runner, 3.4L (5VZ-FE), 5-Speed (R150F), 4WD, 4.10's, 33's 1991 Toyota 4Runner 4 Door, 3.4l (5VZ-FE), 5-Speed (R150F), 4WD, 32's, 4.10's |
#6 (permalink) |
Staff
Thanks guy's, I just picked up some black hi temp RTV silicone a bit ago.
I had to take out my Husky floormat last night and let the carpet dry some, as it is still very wet, and stinks bad. No silicone Hole is very open, and you can see how the water traveled down the wires into the interior. After silicone Great gobs of goober! I squeezed a ton of stuff into the hole itself, and coated the wires real good too. |
#7 (permalink) |
Corey,
As far as the RTV, what you got will work fine. When you go to put it on, try this: Pull the wires back thru the fire wall as much as you can (shouldn't need more than say 1/2 ") goop the RTV around the wires really good and push or pull the wires back thru. Then seal up around the grommet with a little more RTV. By pulling the wires back thru a little this will allow the RTV to seal on the inside of the grommet better. As far as the water in the carpet. See if you can find one of those self serve carwash places that has the carpet shampoo machines. That should help in not only getting rid of the smell but will also suck the water that is left in the carpet out. Or use a shop vac and some fabreeze in a pinch. Hope that helps, Brad
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew |
#8 (permalink) |
Staff
Thanks Brad, those are some good tips on the wires.
When I did it earlier, I did not move the wires back and forth, but there should be a lot inside the hole. I might work on putting some more on tomorrow. I have a Shop Vac here, and I may dig it out later also. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Drilling new grommets through firewall | Erich_870 | Vehicle Audio & Home Entertainment | 7 | 02-19-2007 07:29 PM |
| silicone | CraZyRunner | 86-95 Trucks & 4Runners | 10 | 02-01-2006 08:53 AM |
| Quick 2nd gen help... grommets in firewall ? | nrgetic99 | General Vehicle Related Topics (Non Year Related) | 6 | 12-13-2005 05:39 AM |
| Half moon grommets? 22re | gumbo | Maintenance & Repair Archives | 8 | 01-30-2004 07:12 PM |
