Signs of worn ball joint? - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 05-20-2004, 01:42 PM   #1
az4x4runner's Avatar
I have this clunking sound (sometimes just a clicking sound) coming from my passenger side suspension when I hit a rock or a bump with that tire only. I kind of suspected one of the ball joints, I looked it over and I really can't tell.
Does it sound like that may be my problem?
Thanks,
Bryan
az4x4runner is offline   Reply With Quote
Old 05-20-2004, 02:17 PM   #2
mt_goat's Avatar
Thanks,
Bryan
It could also be a bad bushing or a loose bolt somewhere too. Check the upper and lower control arm bushings, shock bolts and bushings as well as the ball joints.
mt_goat is offline   Reply With Quote
Old 05-20-2004, 02:28 PM   #3
Guest
Lift the front end off the ground and start working the tires from top to bottom and side to side looking for loose parts or worn bushings. You should not feel any play when you grab the top and bottom of the tire and pull in & out. Also look for the boots oozing grease. That is a sign of a noisy bj. i just replaced mine with the help of a good buddy.
Yoter is offline   Reply With Quote
FS[MidWest]: 1.5" ball joint spacers 4x4YOTA Axles - Suspensions - Tires - Wheels 2 08-23-2016 10:08 AM
FS[MidAtl]: 1979-1983 Pickup Parts For Sale - Post Build Garage Clean Out kawazx636 Vehicles - Parting Out 31 02-23-2016 12:57 PM
94 22re Strange Engine Noise (video!) Davebarbier 86-95 Trucks & 4Runners 32 11-03-2015 04:28 PM
g52 transmission question regarding axial movement?? hiluxinargentina 86-95 Trucks & 4Runners 0 10-01-2015 12:12 AM
FS[SouthCent]: TX - 4Crawler Ball Joint spacers crash813 Axles - Suspensions - Tires - Wheels 0 09-27-2015 08:15 AM
Tags
2003, bad, ball, bump, clicks, durango, hit, joint, joints, show, signs, symptoms, tacoma, toyota, worn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
