Side Mirrors Wobble
Side Mirrors Wobble
I have the Power Mirrors and they wobble and I can hear the passenger one rattling while driving. The mount that connects the mirror to the truck is tight. However, the pivot point is loose. There are 3 phillips screws underneath the pivot which are tight, but when you move the mirror up and down the phillips screws are moving too. Does anyone know how to tighten this up without replacing it?
Thanks
Thanks
1 Post
Simple fix.
Pop off the inside cover in the corner of the window where the mirror mounts to the door. Mine have my tweeters mounted in them. There are 2 or 3 bolts that need tightening. Pop the covers back on.
Just to give you a visual. The picture is of the type of mirror I have. The rectangle is where it is loose, and the arrows indicate how to make it rattle.
http://i3.photobucket.com/albums/y75/HamSolo/mirror.jpg
Thanks.
Thanks.
Have you tried completely removing the mirror and disassembling it to try and locate where the play is?
My 3rd gen had this issue and it ended up just being that the three bolts/screws on the bottom felt tight, but were actually not. I removed them (which was a royal PITA given the years of water/weather they had seen) and got six new ones from the dealership, shot some WD-40 in before I replaced them and they were both solid again.
Just my $.02,
Fink
Just my $.02,
Fink
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
