Side Marker Light Question - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-08-2007, 12:59 PM   #1 (permalink)
Speedy's Avatar
Send a message via AIM to Speedy
I've been researching side marker lights. I've found the tech write-ups and a few odd and end posts, but no one seems to have tried getting the side marker lights to work with the parking lights AND flash with the turn signals. Seems it should be easy enough with a relay. Anyone tried it?
Also, where do I find the JDM side marker lights? They seem to best match the Hilux Surf.
__________________
-Speedy
Project SportRunner (240 RWHP 259 RWTQ)
2002 SR5 4x4 3.4L V6
TRD SC, URD 2.2" Pulley, URD 7th Injector Kit, Custom Gauges, TrueTrac, Tru Cool 4454 Tranny Cooler, Satoshi Grille, Fog Light Mod, DRL Mod, Sport Hood, TRD Wheels, ISR Mod, Deck Plate Mod, Supercharged badging
Speedy is offline
Old 01-08-2007, 01:10 PM   #2 (permalink)
You can try eBay for the JDM side markers, but for the wiring its fairly simple. For the wiring you would have to tap one wire to the parking lamp and one wire to the signal lamp, I forgot exactly which power wire goes where but that should be easy to figure out since its only two wires. With this the Side Marker powers on when you turn on your parking lights and it also flashes when you turn on your signal lights.
__________________
97 4Runner Limited
iceman601 is online now
Old 01-08-2007, 01:16 PM   #3 (permalink)
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
Send a message via AIM to drguitarum2005
Quote:
doing it this way, however, raises the chances of some weird electrical things happening with current going backwards to either the turn signals or parking lights, causing either blown fuses or just unnecessary illumination. the best bet would be to use relays. maybe splice into the parking light wire and have that activate the relay coil connecting the light to a direct power source and doing the same with the turn signal, or wiring into the turn signal directly so that the circuits are isolated and they dont BOTH have a direct connection to both lights.
__________________
-David
2000 Taco TRD Access Cab
v6 | 5spd | 33" BFG A/Ts | 33" PC Mud Terrains | OME 882's | Bilstein HD struts front | Rancho shocks rear | Chevy 63" leaf spring swap | Custom sliders | Custom front bumper |3" BL | U-Bolt flip | Flowmaster exhaust | Kenwood Speakers | Grey Wire Mod | Aux. Reverse Lights | Deckplate Mod | Lots of lights
Pictures
drguitarum2005 is offline
Old 01-08-2007, 02:49 PM   #4 (permalink)
ebelen1's Avatar
I let the experts do the wiring but mine lights up w/ the stock lights and blinks w/ the blinkers. As far as where you get them CDCUFF has some. I bought 2nd gen OEM ones from him and I love them.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 01-08-2007, 02:57 PM   #5 (permalink)
Speedy's Avatar
Quote:
This sounds like what I'm looking to do. Who were the "experts" ?
__________________
-Speedy
Speedy is offline
Old 01-08-2007, 03:07 PM   #6 (permalink)
Speedy's Avatar
Also, how did you mount them? Did you do the dremel cutting on the fender, etc? I took a look at Ebay for JDM side markers and there's a lot of different styles but without holding them in my hands it's hard to tell how they mount. If we could find some with a foam seal of some sort built in they'd be ideal.
__________________
-Speedy
Speedy is offline
Old 01-08-2007, 03:47 PM   #7 (permalink)
BigBluePile's Avatar
Send a message via MSN to BigBluePile
Try this:
http://www.4x4wire.com/toyota/tech/tacoma_turn_signal/
No idea what truck you have. This is REALLY easy if you have the tacoma. Little more in depth for Yota's with the original front grill (80's through 95ish) marker lights. It is very simple and works great. You'll be using the #1157 bulb amber/clear which is a dual filiment bulb. This rewiring is REALLY easy. Plus its a lot brighter, once you start this mod YOU CAN'T turn back. I think I spent less than $20 all together.
__________________
Logan
aka: BBP
Kiss my IFS.
RB4R Life Member #2
THE ULTIMATE TOYOTA RESOURCE
'86 4Runner SR5 22R-E
4" Procomp/Superlift/Rancho 9000x/BudBuilt skids. Downey Header/Magnaflow exhaust, Supra AFM. 315/75R-16 Baja Claws, 4.88's, TrueTrac rear.
Rear disk kit/trans e-brake. Addicted Offroad winch bumper/MM 9000
Current pics
'06 4Runner Sport
270/65R17 BFG All Terrain KO's
Quote:
Originally Posted by Junkers88 View Post
Admit it, you like reading my posts. It reminds you of the days before your runner was the monster that it is now.
BigBluePile is offline
Old 01-08-2007, 05:59 PM   #8 (permalink)
ebelen1's Avatar
Quote:
Experts meant those that know how to wire. In my case, a buddy w/ an audio shop did the wiring and the dremel cutting. He's done a ton of these from back in the day when they were very popular. He cuts a paper template based on the back of the side marker and uses this as a guide.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 01-09-2007, 09:47 AM   #9 (permalink)
Speedy's Avatar
I have a 2002 SR5 4Runner.
We're talking about this type of side marker light correct?
http://www.yotatech.com/showthread.php?t=75843
I didn't know any 4Runners in the US came with these, 2nd Gen or otherwise. Do you know which model JDMs you used?
__________________
-Speedy
Speedy is offline
Old 01-09-2007, 03:39 PM   #10 (permalink)
ebelen1's Avatar
No US runner came w/ side markers. The ones I have are from a 2nd gen runner and say "Toyota" on the actual light. They are amber in color and not clear.
__________________
____________
Edwin
1999 SR5 4unner
ebelen1 is offline
Old 01-10-2007, 08:48 AM   #11 (permalink)
Speedy's Avatar
Got a source for these and a couple of pics? Do these install the same way as the VW markers?
__________________
-Speedy
Speedy is offline
Old 01-10-2007, 09:54 AM   #12 (permalink)
These look pretty darn close to the JDM side markers:
http://cgi.ebay.com/ebaymotors/JDM-T...spagenameZWDVW
__________________
97 4Runner Limited
Old 01-10-2007, 09:57 AM   #13 (permalink)
Speedy's Avatar
I'd be perfectly fine with something like this, my only concern is how they attach to the vehicle.
__________________
-Speedy
Speedy is offline
Old 01-17-2007, 03:32 PM   #14 (permalink)
Speedy's Avatar
Has anyone looked into Honda S2000 front marker lights? I was at a Honda dealer today and they look like they'd fit flush as the S2000 fender has no bevel around the lamp assembly.
The only question I had was how they attach to the car, and how you change bulbs. I didn't see how the lens snapped off the base.
The dealer quoted me $45 for the pair with base, but said that the wiring harness was attached to the car's main harness so I'd have to engineer something there.
Any thoughts?
__________________
-Speedy
Speedy is offline
Old 01-18-2007, 09:13 AM   #15 (permalink)
Midget96's Avatar
I had the S2000 sidemarkers on my old Integra. They require a specially sized hole to fit and then you simply press them in and they snap into place with the two metal locking tabs. You don't remove the lens to replace the bulb; you pull the socket out from the back to do it. I gurante e you that you'll never have to replace the bulbs, though.
Go here if you want a ton of options for sidemakers. Most are $27 a pair.
http://passwordjdm.com/search.asp?st...chCriteria=all
Midget96 is offline
Old 02-22-2007, 04:56 AM   #16 (permalink)
CDUFF7's Avatar
btw, I am the guy who sold them to ebelen - the real ones with wire intact from a Hilux Surf in Japan.
__________________
See my JDM Auctions on Ebay: http://shop.ebay.com/chaser_tourer/m..._from=&_ipg=25
Thank you :-)
CDUFF7 is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
04 4runner: front side marker light replacement jmx General Electrical & Lighting Related Topics 0 07-05-2007 08:54 AM
96 headlight and side marker my86yota The Classifieds GraveYard 4 02-21-2007 07:06 AM
How do i replace rear side marker light for a '03 4Runner? jxd315 03+ 4Runner/GX470, & 05+ Tacomas 8 10-07-2006 07:21 AM
what type of wedge bolts for side marker. dexter 95.5-2004 Tacomas & 96-2002 4Runners 0 08-26-2003 07:33 PM
2009 InternetBrands, Inc.
