'Shuddering' when braking.
Hi Guys,
When I drive my '99 down a fairly steep gradient and I start to brake the car feels likes its shuddering. It feels like maybe the ABS is working but I don't why it would since I'm not braking very hard.
It happens when slowing down from 60 and it only happens on a downhill gradient.
Any thoughts?
Any thoughts?
I had this same problem with my 99. After having them play with the rotors time and time again, I just opted to get newrotors and performance brake pads and haven't had a problem since.
It's well worth the money and no more of that awful body shuddering coming down from the mountains.
Carsten,
Sorry for the delay in replying.
I don't have pictures but I bought some Brembo cross drilled rotors with performance pads off Ebay. I got a good deal and like I said, it's made a big difference. That shuddering is the worst feeling besides the ABS!
Hope that helps.
Hope that helps.
Don't mean to step on this thread but I'm having a similiar problem on my '94.
I just replaced the rotors, pads and repacked the bearings, and I still have a slight pulsation/shudder when breaking.
I replaced the rotors with the Tru Stop rotors and used Performance Friction pads for the '96 Land Cruiser.
It is more severe at highway speeds, but still noticeable when braking above 40mph. The brake job did correct most of the problem, but not all.
I haven't adjusted the rear brakes or replaced the shoes yet, so I wonder if the rears aren't working as hard as they can, and this could be causing the fronts to do more than their share? Is this possible?
What else can be causing this? I thought about calipers, but wouldn't the car pull one way or the other if one was about to seize?
Any ideas what else I can check?
Drive down a street (preferably a non-busy one), I think you have the turn type knob from the dash parking brake, so with it turned 90 deg (as if you are trying to release it) and your finger on the release button, pull on it (not hard), just enough to feel resistance. Don't hit the brakes when doing this test, just use the parking brake. If you feel shudder, it's your drum, not shoes that are out of round or commonly refered to as warped. Even though a simple fix is turn your drums, it's better to just go ahead and put in new shoes while your at it. Drums CAN BE turned at any local Kragen's/Chuck's whatever they call it at your town. If you have any questions get back to the board and we'll be happy to answer your questions.
Thanks! I tried your suggestion this morning, and sure enough I felt the same shudder. Not only that, but I noticed I could barely slow the rig down using the hand brake. I guess I need to get some work down on those rears.
What can be done for rear brakes?
1. adjust
2. turn drums
3. new shoes
Anything else? And I take it that the rear drums on 2nd Gen 4runners don't suffer the same characteristic of the rotors, in that you really shouldn't bother with turning them, but rather replace them.
Thanks again.
1. adjust
2. turn drums
3. new shoes
Thanks again.
1. adjust
2. turn drums
3. new shoes
Thanks again.
1. adjust
2. turn drums
3. new shoes
Thanks again.
Originally posted by jefferino
I have the same problem on my 4 Runner that I just bought, 94.... Those shops aren't in Michigan, anywhere else I might be able to get the drums turned?
I don't have a problem with turning the drums, but with front rotors on these vehicles being notorious for warping fast, I wouldn't bother. You're just going to end up dealing with it again after a few thousand miles. Brakes are one area where I can not tolerate slop in any of my vehicles.
crammit442
7
11-29-2017 12:30 PM
jennygirl
11-17-2015 11:24 AM
