Shocks that dont STAND???
I got a pair of Doetsch Tech shocks for my 1.5 downey coils in the rear. When I got them I had to pull up the head. From all my past experiences with shocks (monroe,trailmaster, rancho) they have always stood up. How will I get performance out of a shock that doesnt reposition itself? Is this normal? There customer service doesn't know their azz from their elbow.
thanks
thanks
1 Post
My bilsteins I couldn't budge one bit by hand. But I know they definately do their job when I'm driving. My OEM shocks that I replaced with the Bilsteins I could definately push in and out by hand. Subsequently you can guess that the ride quality of the Bilsteins is much firmer.
shocks are usually controlled by a valve that has a certain flow rate on compression, and another on extension. all they do is control the jounce and rebound of the suspension, they're not springs. most allow for a quick compression and a slower rebound.
shocks behave differently... the pro comps i got were compressed when i got them and i had to stretch them out to install them, thats how their valving is.... i love the ride on my es 3000s.....
its all in the valving and depending on what the use is or even as pciky as what some manufacturer decides can dictate if it will stay compressed or rebound itself... as previosly stated, they are not springs.... and thus they control the rate at which the vehicle responds due to the springs.....
Its the difference between a gas pressurized and standard hydraulic shock. They both work the same way: a valve being drug through fluid. With the addition of pressurized gas, the gas will act like a mild spring (same as an air shock, just weaker), allowing the shock to self extend and helps prevent the fluid from foaming.
How a Shock works
How a Shock works
as unhappy said, a gas pressurized, (usually nitrogen) shock will expand (stand up). Why pressurized? It helps keep the oil from foaming (creating air bubbles) when the shock is doing its thing.
Technically all the shock needs to do is dampen; most do this by forcing oil through a small orifice, the energy from the suspension is converted into heat this way, which is then dissipated.
Fade happens from foamed oil that is hot. both conditions lead to a thinner oil which passes through the orifice easier and thus reducing dampening effectiveness.
1 Post
Originally Posted by USAtruck6
Thats one firm ride....
You want firm? Try cranking your torsion bars up an inch and a half with an extra leaf spring in the back with a set of ranchos like my truck had at one time when the previous owner had it. OUCH! You'll be seeing the chiropractor after a day of driving!
dirk89
10-01-2015 05:15 PM
hiluxinargentina
09-30-2015 05:51 PM
