she won't run
she won't run
after work today i wanted to clean my second gen runners air box so i took it apart an decided to put in a new KnN filter. I put all the stuff back in place and now the damn thing won't start. The engine will turn over fine but it just wont't run. it sounds as there isn't any fuel getting into the engine. Can anyone tell me where the fuel filter and pump are located. any other suggestions welcome
thanks
thanks
It sounds like you may have forgotten to reconnect your mass air sensor. Do a good once over and make sure everything is plugged in/hooked up. It is located right after the air filter. Odds are highly unlikely that your fuel pump or fuel filter or any part of the fuel system is at fault if it was running good before you took the airbox off. good luck
