shaky hood
shaky hood
I have a 91' runner and every time reach about 80 mph or drive in high winds my hood starts to shake. I am sure that it is nothing serious but it seems a little excessive. I took a look under the hood and it seems that the actual hinges are behind the firewall. Does anyone have any experience with this??
Have you checked the hood adjustment grommets/screws at the front upper crossmember (by the headlights)? If not, make sure those are not too far down, they can cause excessive flutter too.
But I agree with what's been said, a bug shield causes more hood flutter. Mine is annoying, but only if I stare at it, and at 80+MPH, I should be looking elsewhere
[QUOTE=<96 Runner>]Have you checked the hood adjustment grommets/screws at the front upper crossmember (by the headlights)? If not, make sure those are not too far down, they can cause excessive flutter too.
This is what helped my hood at high speeds.
Thanks for the info. I do have a bug shield i am sure that that contributes. I adjusted those grommets for the hood as well, it helped. Thanks for the help.
Originally Posted by Jason B
Yes, mine never did it until I added it. Also, that shield reduces your MPG by at least 1 mpg.
I keep track of my MPG on charts, so I am going to have to go back and review that. I do remember a slight loss, but I thought that was from my 4.30 gears that I switched to at the same time.
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
TheBFA
02-15-2020 06:55 AM
