| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Shaking once above 65mph?
__________________
-Eric 2002 SR5 4WD Goodyear Wrangler Duratrac 265/75/16C Deck plate + ISR OME 881/890 Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims |
#2 (permalink) |
Maybe your 4Runner is just living up to your username.
![]() I'd jack up the front end and see if there is any play in the steering or suspension components. You'll also be checking the bearing play at the same time. I wouldn't imagine U-Joints causing a shake at the wheel, but perhaps you could feel a vibration. Grease never hurts though.
__________________
================ 1990 4Runner | V6 3.4 | 5spd | 240 someoddthousand miles | SR5 | SAS | RLS | 35's | ARB | TJM | 217 to 1 | W8000 - four wheels | three sticks | two hands | one trail - visit the sticki chronicles
#3 (permalink) |
i would say that a tire weight might have fallen off or it was'nt balanced right
(when i worked at a tire store we did lots of re balanceing) take it back and have it redone for free
__________________
1994 toy 22re- http://www.yotatech.com/f86/nocalsvx-s-94-toy-104593/ 2006 Subaru Forester XT -some mods/awd 5spd 1994 Subaru SVX- hwy runner 84 RX7- drag car build |
#4 (permalink) |
Redo the balancing, then check your steering stabilizer, then check the wheels and tires for being out of round to make sure if you cant figure it out
__________________
96' T100 SR5 4x4, ISR mod, Custom ABS snorkel, KC 57's Hella optilux el cheapo backup lights. Cobra 19III CB, Firestick 4ft antenna, Bilstein shocks. Be polite. Be professional. But, have a plan to kill everyone you meet. |
#5 (permalink) |
there was no change from before the balance to after the balance. Thats why i think it might be something else. ill take a look at steering stuff. how should i go about checking it throughly? Its more a really quick oscillations. its not a huge shake. maybe 1/2 in to each side but it gets faster as speed increases.
__________________
-Eric 2002 SR5 4WD Goodyear Wrangler Duratrac 265/75/16C Deck plate + ISR OME 881/890 Tundra 231mm Brakes - yes they DO fit the stock 5 spoke rims Last edited by twitchee2; 05-16-2008 at 11:46 PM. |
#6 (permalink) |
A lot of people have problems with worn steering rack bushings.... If you can get a buddy to turn the wheel when you are under the truck, check for play in that area.
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#7 (permalink) |
so i take it i can do that with the tires on the ground?
__________________
#8 (permalink) |
Try swapping the front tires to the back and see if that changes anything. One tire being out of round will cause the same thing - I had to get a BFG replaced under warranty after 4000 miles and about 4 re-balances - that fixed the same issue you describe.
Yeah you can (actually: should) check the rack bushings on the ground. Just turn the steering wheel and watch the rack.
__________________
Jon 97 4Runner 3.4 * 4.88's * ARB Lockers F/R * ARB compressor * Sonoran Steel numba 1 * 285 BFG AT/KO * TJM 17 * BudBuilt Skids * Stubbs Sliders & BBQ sauce * Irbis out back * Various Electronic Gadgets |
#9 (permalink) |
Did you physically check your U-joints to see if there is play in it? Mine did that in my old 1988 V6 x-tra cab from about 60+miles per hour and it turned out to be the U-joint. (I found that it occurred occassionally after I put a lockrite in the rear.) Took a socket to it and the shake was history.
Cheers and good luck.
__________________
1997 3.4 4Runner, 5spd, e-locker, SS#1.1 Lift, 265/75/R16 Dick Cepek FCII Coming soon: ARB front bumper with T-Max or Warn winch, sliders, snorkel, etc. |
#10 (permalink) |
I have this same problem. Right at 60mph i get a bad shake but it stops about 65 - 70. It has done that since i got it and never changed with alliment or balancing.
I am thinking it might be the bushings. They are cheap to replace i just have not got around to it. If you figure it out be sure to post it.
__________________
Just call me TA 2000 Toyota 4runner Limited 3.4l V6 Auto SUPERCHARGED, URD 7th, 2.2 pulley, Doug Thorley Headers - My truck All the Mods that can be done to 3rd Gens Thread My thoughts on Gun control summed up quite nice: “Gun control runs aground on this simple fact: people who would use guns to break laws would also break laws to use guns” |
#11 (permalink) |
I've actually had this problem. I just rotated/balanced the tires, and it went away. Course, you could have other problems. Try the easy stuff first!
__________________
#12 (permalink) |
Usually all toyota trucks have this problem.
__________________
2000 4Runner 4x4 Sr5 173K, 2x Procomp lights, 3" Toytec lift, Diff. drop, Gunmetal painted rims, 285/75/16 Dunlop Radial Mud Rovers, audio system, TomTom GPS, Summit Racing Muffler, Rear Cargo Storage/Sleeping Deck. |
#13 (permalink) |
well i think you guys are right about the steering bushing. I noticed that if i was going strait for a while it would not shake. Its more just vibrating the car more then shaking the steering wheel. It would continue to be nice and smooth until i turned to correct for wind or a bend in the road. Then it would shake and eventually stop after a while on a strait away. Im going to physically look at them later tonight or tomorrow but where can i order bushings?
__________________
#14 (permalink) |
Checked it out in the parking lot and the whole rack moves a good 1/8-1/4 inch in the bushings. ill be ordering new ones in a day or 2. How difficult is the job?
__________________
#15 (permalink) |
I do have this problem too. Mine vibrates when I brake, and when I go at high speeds. I know the brakes are probably the rotors. I will get a new set, and rotate the tires. If that doesn't do anything, watch out!
__________________
Old Rig: '95 4runner | White | ISR | 193,000mi. | Totalled. |
#16 (permalink) |
I've had this prob...after replacing the all 4 shocks, new tires,alignment,poly steering rack bushings, balancing & balancing & rotating...the problem is still there. The tre's seem tight but I notice some odd play in the steering. I lifted the front of the truck off the ground and removed the boot on the driver's side steering arm. When I push the tire in and out, it looks as if the horizontal steering rod travels up or down slightly in addition to moving in and out. Maybe the whole steering rack is to blame? How would I be able to determine if it's the rack?
__________________
90 4runner 4cyl-5spd, detroit lockers - 5.29 gears,All Pro hd rear coils, 25mm torsion bars, 2" bl,Warn manual hubs, 33s 99 4runner 6cyl auto RIP (hit a deer) 97 4runner V6-5spd 4x4, e-locker with 2wd/4wd mod, isr & airbox elbo mod Last edited by Sandman; 05-19-2008 at 05:56 AM. |
#17 (permalink) |
#18 (permalink) |
Is there a walkthrough for replacing the bushings?
What are all the things that could be the problem if a yota is getting very slight vibration at 65-70mph? I know it could be tires/balance/alignment, but all that is covered with mine. Then you have the bushings and steering rack? Which is what I'm thinking the issue is. What else could it be if that doesn't fix it? Has anyone ever had this problem and fixed it? I keep hearing of the issue but no 100% fixes. |
#19 (permalink) |
Maybe all of your toyota trucks......
The easy solution would be to avoid driving between 65-75 miles per hour hehe...
__________________
Low down and durrrrrrrty Rock stacking Web Wheeler. Locked, lifted, trussed, SASsed, triangulated, dual cased, shaved, armored, gusseted, hydro'd, blacked out, crapped out, mashed up, merderrrrrd out and ready to hit the mall! It's a Jaap thing....You wouldnt understand |
#20 (permalink) |
I'm thinking new steering rack now
__________________
90 4runner 4cyl-5spd, detroit lockers - 5.29 gears,All Pro hd rear coils, 25mm torsion bars, 2" bl,Warn manual hubs, 33s 99 4runner 6cyl auto RIP (hit a deer) 97 4runner V6-5spd 4x4, e-locker with 2wd/4wd mod, isr & airbox elbo mod |
#21 (permalink) |
rack ends or maybe your tierod ends, you can check them by jacking up both sides that would permit you to move the tires by hand... another good/knowledgeable eyes will really be a help.
#22 (permalink) |
I have another post where someone posted write up for replacing the bushings. im replacing mine in a little later today.
__________________
#23 (permalink) |
Do you have a link to that thread??
#24 (permalink) |
__________________
#25 (permalink) |
I have the same problem, changed rack bushings, new tires and alignment, still vibrates - checked u-joints etc. how can you tell if the hub is bad?
__________________
2000 4Runner SR5 Stock for now Intake elbow & ISR removed ~ High Flow Air Filter Extended rear differential breather Polygraphite Steering Rack Bushings 265/75/16 Kumho Roadventures (Maxxis Bighorns comming soon) IPF lights Auxilery Reverse Lights WabFab quick disconnect sway bar links 91 Mustang GT Modified |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can worn out shocks/struts cause vibration above 65mph? HELP! | LSUMatt1514 | 95.5-2004 Tacomas & 96-2002 4Runners | 135 | 12-18-2007 10:07 PM |
| Trouble at 65mph | 95ToyotaPU007 | 86-95 Trucks & 4Runners | 14 | 10-16-2007 06:32 PM |
| Sub+65mph=top Off | just a 22re | 86-95 Trucks & 4Runners | 25 | 03-18-2007 03:01 PM |
| Vibration - yes at 65mph! | Roadtripr | 95.5-2004 Tacomas & 96-2002 4Runners | 11 | 02-02-2006 10:49 AM |
| Slight vibration at 65mph, feels like in the rear 1997 4 Runner, please help | BOSTON4RUNNER | Maintenance & Repair Archives | 10 | 09-07-2005 08:04 PM |
