shackle lifting
Old 07-24-2003, 09:46 AM
pigcake's Avatar
shackle lifting
When exteneded shackles are used for lifting the rear are you required to add a leaf? Also, what is the benifit of a greasable shackle? Squeeks?
Old 07-24-2003, 09:52 AM
socaleric2002's Avatar
I JUST DID AN ADD A LEAF. FROM MY UNDERSTANDING, YOU DO NOT NEED AN ADD A LEAF TO DO A SHACKLE LIFT, BUT YOU CAN USE BOTH FOR EVEN MORE FLEX AND LIFT
I DID MY LIFT WITHOUT THE SHACKLES.
Old 07-24-2003, 10:08 AM
pigcake's Avatar
Would just doing a shackle lift make a ride more stiff, soft, or stay the same?
Old 07-24-2003, 04:44 PM
seafarinman's Avatar
The shackle lift will ride exactly the same. I originally added a shackle lift because of the rear end sag that I was getting with my camper top. It lifted the rear 1 1/2" but not enough, so I ended up going with an add-a-leaf as well. With the camper top off my truck, well lets just say that the rear is a lot higher than the front! And the heavy Badland fromt bumper and winch don't help with that either! But I do have the SAW torsion bars as well.
Old 07-24-2003, 05:11 PM
pigcake's Avatar
Thank you sir...
suppra87
07-15-2021 05:15 PM
1uzRunner
63
11-10-2018 03:58 PM
punks_is_4x4
05-31-2016 06:03 AM
matthew138
09-03-2015 08:21 AM
Ryall
09-02-2015 06:48 AM
Quick Reply: shackle lifting
