Scangauge II/XGauge question
01 Taco 3.4L
In another thread I saw that the ATF temp codes were available and grabbed my manual and put them in. I happened to be glancing through the quick start guide and it mentioned in the "How to save fuel" section that there was an AVG gauge that showed Average Fuel Mileage. I can't find it and there does not appear to be any codes for it. Anyone have any ideas?
On the same subject, while I am off this week I was going to start playing with some of the codes, in particular ones related to the O2 sensors, to see if they worked on our vehicles. Does someone have a list or is there a FAQ or thread somewhere that lists all the codes that the manual has that work with our trucks? Maybe even some not listed ones like the ATF?
I didn't see anything specific for Tacoma's, but this might help...
http://www.scangauge.com/support/pdfs/XGAUGE.pdf
For trans temp
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
Altitude Gauge (Feet)
TXD: 07E02133
RXF: 04610533
RXD: 2808
MTH: FEEE00016B08
NAM: Alt
Air to Fuel Ratio (Lambda)
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 006400800000
NAM: AFL
Air to Fuel Ratio (True Air to Fuel ratio)
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 05BE00800000
NAM: A/F
Atmospheric Pressure (PSI)
TXD: 07E02133
RXF: 04610533
RXD: 2808
MTH: 000A00450000
NAM: PSI[/QUOTE]
Pulled from a thread over at t4r.org
TXD: 686AF101B4
RXF: 044105B40000
RXD: 2808
MTH: 00090005FFD8
TXD: 07E02133
RXF: 04610533
RXD: 2808
MTH: FEEE00016B08
NAM: Alt
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 006400800000
NAM: AFL
TXD: 07E02144
RXF: 04614544
RXD: 2808
MTH: 05BE00800000
NAM: A/F
TXD: 07E02133
RXF: 04610533
RXD: 2808
MTH: 000A00450000
NAM: PSI[/QUOTE]
TJWilly
07-31-2015 02:05 PM
