| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
SAW's and OME
#2 (permalink) |
No problem running the SAW/OME combo. There are several guys here that run that (Schaefer, phong and Darren off the top of my head). You won't need the spacers with the SAWs since it is adjustable. Just dial it to the height you desire. One of the big issues is the price. OME/spacer is a lot cheaper than a set of SAWs.
Check out the Toyota SUV Suspension Lift Collaboration from ODW. The article has feedback on several different suspension setups. If you haven't done so yet use the search function. All sorts of good info available.
__________________
Lance 2001 4Runner Limited 4X4 -- 315/75R16 MT/Rs | MT Classic IIs | Dual ARBs/4.88s | (F) 5125/Tundra Coils (R) 5125/LC Coils | 4Crawler 1.5" BL | Aisin Manual Hubs | Slee Sliders | Sonoran Steel Rear Bumper | TJM T-15 w/ Warn M8000 2004 Land Cruiser -- OME Medium Lift | Nitto Terra Grapplers |
#3 (permalink) | |
Quote:
OME struts $200 Spacers $130 Shipping $35 TOTAL $490 SAWs $675 thats only $185 difference, i dont consider that a lot. IMO, do it right the first time.
__________________
Ryan New: 2008 4Runner Sport. Mild, not wild. Old: 2000 4Runner 305s, Locker, TJM, Warn, Skids, Sliders, SC |
#4 (permalink) |
I stand corrected Ryan. For some reason I thought the price difference was more.
Live and learn...
__________________
#5 (permalink) |
costs
It is a bit more....
SAWs for 675.00 is for just a pair.... fronts... you still have to get coils and shocks on the rear... dif drop.. From my calculations... the saw config with OME rears are a bit more than just a OME setup... but i guess prices vary... considering a cornfed spacer is about mid to upper 100's... im sure the figgure is around 400-500 difference... I could be wrong since im not looking at my excel spreadsheets, since im not at home. Ducky |
#6 (permalink) |
my comparison was for front only, either way you gotta spend $250 for rear coils/shocks.
__________________
#7 (permalink) |
I'd beg to differ a bit on the prices- I'm pretty sure the front OME set-up is ~225. That's what I paid for my rear set-up, and the prices I saw for the front from Central offroad were in that same range. The spacers are only that expensive if you go with Corn.- Revtek 1" spacers are significantly cheaper, and OME trim packers can even be used to level out the front. Shipping isn't really an issue- Ducky can pick up the parts directly from Central Offroad in Washington, or pick them up directly from ARB in Seattle, which is what I did for my parts. The SAWS option up front is going to end up being much more expensive.
With that said- the adjustablility of SAWS are nice- if you decide to add a bumper, winch, etc. which is going to add more weight to the front, you won't have to worry about buying another set of coils to get the front lifted again. From what I understand, the ride is pretty sweet as well. I'm in the same boat as you Ducky. I really like the look of the ARB bumpers, and all though I won't be getting one for a while, I'm thinking about going with the SAWS for that reason. My OME set-up for the rear is sitting on my balcony, waiting for me to make up my mind!
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
#8 (permalink) |
Coil Overs and ARB bumper questions
I have a 2004 double cab taco and I'm regualrly running back and forth on a logging trails. Alot of night time critter obstacles and northeast brush so went with an ARB bumper but my front end is sagging. Other than the addition of my new heavy bumper i'm still running TRD stock.
If i only install front coil overs but keep the rest of the stock suspension would that give me the lift i need for the front bumper, give me a more level ride and also give me better suspension for logging roads? what else would i have to do if anything? Did i just open up a can of worms? I want to keep it simple so it's good on the road and better on the logging roads Thanks s |
#9 (permalink) |
i am running adjustables up front and ome in the rear.
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#10 (permalink) |
I'm new at this so adjustables mean coil overs where i can adjust the collar to level the rig and your running ome shocks or shocks and springs in the rear?
How does it ride? Is the weight of your custom bumper equal to the ARB? |
#11 (permalink) |
Yeah adjustable is a coilover, where you can crank them up or down to adjust the ride height. I am running ome 891's in the rear, and bilstein 5125's. The front bumper weights a tad less than a arb, but once i get a winch in there it will be heavier. It rides nice right now, bumps are alot smoother than stock.
__________________
#12 (permalink) |
Can i install the front coil overs and wait a few months to do the rear or should i do it all at once?
#13 (permalink) |
You can, but it depends on the coilover how far you can crank them down, or you could ride with the socal look. I ran for about 8-9 months on stock suspension with the bumper on, and the only thing that really sagged was my rear end.
__________________
| Tags |
| dual, sawcom, wwwdual, wwwome |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Installed my ome 891's and Saw's finally... | j-man | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 03-09-2007 10:42 AM |
| Been looking at Chain Saw's? | Rivalred | Off Topic Talk | 32 | 01-19-2006 10:12 PM |
| Replaced the Fab's with SAW's | WATRD | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 02-10-2003 09:05 AM |
