Satoshi grille is on! (pics)
Old 02-17-2006, 01:28 PM
potsy's Avatar
Location: Ocean Beach, CA Five square miles surrounded by reality.
Thanks to ASU4runner for swapping grilles with me. I did this a little different than the standard write-up. I cut the lower right and left connection points out from the grill for a cleaner look. When I cut the inside bars out of the grille, I left as much as possible on the sides, so I only needed to use bondo (no fiberglass) to fill the small gaps before I sanded and painted the inside black. And, I used zip ties to hold the mesh on, instead of twisting a bucnch of wire.
Old 02-17-2006, 01:34 PM
Funrunner's Avatar
Very different. I like that look.
Old 02-17-2006, 01:40 PM
Tacoclimber's Avatar
Very cool... Looks great!
Old 02-17-2006, 01:46 PM
Bob_98SR5's Avatar
potsy,
nice work
one question: is that bondo backed w/ any fiberglass? bondo is not a good filler unless it has something behind it
bob
Old 02-17-2006, 01:50 PM
hotlavaaaa's Avatar
that looks jdm tite yo.
Old 02-17-2006, 01:57 PM
One More Time's Avatar
I like that license plate mod too...
Don't worry, I don't think anyone here is more of a threat to your lic. plate number than anyone off the street.
Old 02-17-2006, 02:05 PM
potsy's Avatar
well, when i cut out the main bar, i cut it along the side so that there was kind of an indent that i needed to fill with bondo, but it wasnt a hole as shown in some of the write-ups. the gaps left by the smaller upper and lower bars i used tape to cover from the back and then used bondo over that to fill. i basically built the sides up about a 1/16 of an inch with bondo to smooth the whole thing out too.
Old 02-17-2006, 02:16 PM
calrockx's Avatar
looks good.
i currently have the front bumper lights off my truck, the satoshi grill on my runner is ubobstructed once more and just happen to be seen again haha. i sorta missed it being open like that
Old 02-17-2006, 02:18 PM
potsy's Avatar
are you sure? i was afraid someone might look up my address based on my lic plate number and come and steal my new grille in the middle of the night...
Old 02-17-2006, 02:22 PM
Baker 02's Avatar
Did you check your driveway? Maybe I already did...
Old 02-17-2006, 02:23 PM
FUZION's Avatar
NICE :chicken:
Old 02-17-2006, 04:36 PM
ebelen1's Avatar
Potsy, good job. Welcome to the Satoshi club...
Old 02-17-2006, 07:12 PM
rondo221's Avatar
Potsy..
nice work.. Im currently on the stages of Doing this mod myself.. I have questions.. Since you cut off the 2 bottem connection tabs. how well is you frame on? I like that look.. but I dont like the idea of my grill missing 2 connection points... 2nd.. what method did you use to attach the toyota logo? and would you mind describing that in detail??
where did you place your zip ties?
Old 02-17-2006, 07:51 PM
4RUNN!N's Avatar
Looks good. I like the retro look.
Old 02-17-2006, 09:33 PM
potsy's Avatar
the middle connection point on the bottom holds it on pretty good without the other 2. The grille still rests agains the posts so if you push on either side it doesnt move or wobble.
i took 2 small angle pieces and drilled a hole in the middle (where it bends) for the screw. turn the angle peice upside down and the ends push against the mesh when you screw the badge in, kind of like big washer.
i used four ties on the top, drilling small holes in the mounting point parts of the grille, and then i drilled 5 holes along the bottom using the center mounting point for one of them. the way the grille curves underneath you cant see the bottom zip ties when its on the truck.
i'll take it off tomorrow and take a picture if you want...kind of hard to describe some of this without a visual
Old 02-17-2006, 09:45 PM
964runner's Avatar
just when i was starting to forget about this mod, another one for the list. looks great
Old 02-18-2006, 04:38 AM
sabre's Avatar
mice work. Looks like its floating in the pics. pretty cool
Old 02-18-2006, 06:45 AM
Jonathan's Avatar
Looking good man!
1uzRunner
63
11-10-2018 03:58 PM
Badfish740
09-04-2015 04:21 AM
BigMike
Marlin Crawler
09-03-2015 07:49 PM
128keaton
09-03-2015 05:09 PM
pplusent
09-02-2015 11:56 PM
Quick Reply: Satoshi grille is on! (pics)
