San Diego Test Fit: Pro-Comp 17x8" Series 97 or 99
Old 04-01-2009, 07:45 PM
SharpStick's Avatar
Hi!
I'm desperate and in need of a test fit.
I've done the Tundra brake swap on my '97 4Runner (the big ones, 231mm) and I need to check the fit of a set of Pro-Comp Series 99 or 97s - the steel ones - before I order my own. I'm in San Diego. Who's got?
I will compensate - beer, fame, air-time, whatever fits.
STICK
Old 04-11-2009, 11:29 PM
SharpStick's Avatar
Damn, anyone? At this rate, I'll be the only guy in San Diego with these wheels...
STICK
Old 04-12-2009, 07:51 AM
SnowRunner98's Avatar
I dont see why most of these guys have problems with the stock rims, not a 17x8. should have plenty of room. you ordering them offline?
Old 04-13-2009, 07:51 AM
SharpStick's Avatar
I made the stock rims work - took a little time with the grinder - but I'm concerned the wheel-to-hub center portion (the same region you have to grind on the split-three spoke Toyota 16"s) might be too shallow and rub the caliper. Can't be grinding a new steel rim like the cast aluminum on a used OEM one, you know?
I'm ordering them through Pro-Comp, and I don't want to have to send them back.
STICK
moparbay
03-10-2023 03:50 PM
justdifferentials
Just Differentials
06-13-2022 07:40 PM
justdifferentials
14
06-11-2017 08:36 PM
choppe777
05-16-2016 08:00 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: San Diego Test Fit: Pro-Comp 17x8" Series 97 or 99
