Sahara Bar Woes
Sahara Bar Woes
Well..Now that it's finally installed, and I've driven it a bit.. I don't think I like it sticking way out there. Inclines that were no problem for my stock bumper now drag on the Sahara!! Grr!! I guess the only option is to have new brackets fabbed up, and to cut the "wings" shorter..then re-paint.
Bamachem(sp): You notice this too?
No, I don't have any problem. I actually have MORE clearance. However, I went from the fat-lip 99 bumper with a brush guard to the Sahara Bar, so you really can't compare. You also have a gap, remember? If you get the brackets fixed to reduce the gap, that will give you MUCH better approach angle. I'd try that first BEFORE you go cutting on the sides and try to tuck it in closer to your grill. You may also need some adjustment farther back. I shoved mine as far back as it would go on the brackets and it lines up perfectly with my Limited flares. That means that you'd have about a 1/2" overhang (without flares), but it wouldn't be seen when you get bushwackers or OEM fat flares...
Post some close up pics of the front (from the side) and of the side showing how you have it aligned and I'll tell you if you're off at all...
If you want to see how my approach angle increased, compare the before and after here. I drew a lint between my two front tires where they meet the pavement, then drew a line up to the bottom-center of the bumper to show the approximate approach angle...
Oh, and there was a 1" difference in lift height, so I dropped the first line about 1" below the bottom of the tires...
Bam: How far does it hang over into your fenderwells? It seems like the ends are way to long and if I go further, I'll have issues. Whadda think?
I'll snap some pics after I give it a round of adjustment.
It lines up perfectly with the limited flares, but the limited flares have about a 1/2" lip on them from what i understand, so for you, it's a 1/2" long. That shouldn't matter much on approach angle. Your problem is the gap. As far as approach angle is concerned, 1/2" back would be about the same as 1/2" up. With that in mind 2" up would give you the same as almost 2" back. See what I mean? The 2" gap is a MUCH larger problem than thte 1/2" back adjustment.
Well well well....
I fooled around behind the bumper today..I THINK I got it almost good.
Here is how my bracket is adjusted: (note it's still adjusted down, see below)
It could go UP AND IN more if I were to grind this piece a little bit: (see lower RIGHT where bracket rubs bumper. I could trim that I think)
Whaddya think?
Whaddya think?
Originally Posted by bamachem
Do it. that should give you another 1/2" or so and you'd be set. It looks MUCH better already...
It won't drastically reduce it as long as you were VERY conservative with the notches. You may not have to take it off to do the bracket, but to do the holes, you will. Since your'e messing with it, just do the bracket about a 1/2" and the holes about a 1/4" and you should be fine.
Now, change your avitar to one with the bumper AliGnEd...
Originally Posted by sdastg1
It looks like ˟˟˟˟ ... just trade me for my TJM ... you pay shipping both ways ... you can thank me later
justdifferentials
14
06-11-2017 08:36 PM
WTB[PacNorWest]: Old Man Emu Torison Bars
A2theK
10-14-2015 07:10 AM
potatopants
09-15-2015 06:26 AM
