saggy rear end
Old 12-02-2003, 02:28 PM
offels33's Avatar
saggy rear end
I have a 91 pickup, and it has factory suspension and everything, and the rear end sags a little bit. I want to raise it up like an inch or so. What would be the best way to do this. I heard a block will interfier with the brake lines. Thanks
Old 12-02-2003, 02:38 PM
CTB
CTB's Avatar
Try an add-a-leaf for the spring pack.
Old 12-02-2003, 04:00 PM
Guest
fourunnabilly's Avatar
Either an add a leaf or a block would work just fine...dont worry about the brakes at all...1 or 2" is fine.
Billy
Old 12-02-2003, 04:03 PM
Juggalo's Avatar
Thanks guys, cause I had the same exact question about my truck, except that, I have a cap, and about 100 lbs of equipment in the bed, so do I need to go more than 1'?
Juggalo
Old 12-02-2003, 04:04 PM
Cebby's Avatar
I'll echo the add-a-leaf, but instead of a block you can get longer shackles.
Old 12-02-2003, 04:26 PM
its2slo's Avatar
www.alcan.com solved all of my spring "issues." i had them made for 300lbs. of gear,after that then i start using the spring.
Old 12-02-2003, 06:15 PM
Erich_870's Avatar
I would love to do that, but I have a skinny wallet so I went for add-a-leafs for now if you don't mind, what are thier rates like?
Erich
Old 12-02-2003, 06:40 PM
its2slo's Avatar
$430
Old 12-03-2003, 05:07 AM
Billrunner's Avatar
oh i thought this thread was about a woman.
Old 12-03-2003, 05:44 AM
X-AWDriver's Avatar
the1998sr5
15
07-14-2020 08:35 PM
Daneums
08-20-2015 05:36 AM
rondogracing
07-14-2015 07:00 PM
hangtown88toy
07-10-2015 02:33 PM
akaphilly
07-09-2015 02:18 PM
Quick Reply: saggy rear end
