Sagging back end
Sagging back end
It appears from the site that the back end sagging is quite common is this on all models? mine is a 96 3.0 Diesel 4runner, what do they cost to replace?
You might want to look up Old Man Emu shocks and coils. The coils run about $120 for the pair. The shocks are matched to the springs but they do have several valving rates for you to choose the ride you want. For a little more ($160) Downey makes a popular spring as well. Finally performance products sells a pair of springs for about $200. Most have the Downey HD (heavy duty) and some have the PP and OME. All three will give you about 1 1/2" of lift.
I just looked at our tech section and sadly I didn't see a spring replacement on a 3rd gen. :pat: bad yotatech!
Mike at extreme off road has some great prices and is a member of this board. His website is still being developed but you can use the email links to contact him.
More info could be found using the search function up top.
Good luck and welcome to the board.
Vargntucson
07-04-2015 12:15 PM
