S.C Taco exceleration problem
Hi
3.4 S.C. headers exhaust ,warbro pump, 7th inj ,160deg tstat,trd air filter,elbow removed.
I am not pulling codes or showing a problem on my scan tool..
under med 1/2 pedal exceleration the truck is not pulling it is like the ecu is giving timing(fuel) then taking it away.. If I leave my foot in the same position after 2-3 sec it will smooth out to a nice acceleration..
gas milage is still good.If I dump some 104 in the tank it does get better. I am using 92-93 fuel Amaco or cheveron only.I cleaned the air flow sensor and the throttle body it did seam to help some. the O2 was replaced about 2 months ago.
when I put it to the floor it goes pretty good but I felt it pull better in the past.. I never reset the ecm after the O2 was replaced or the maf/tb was cleaned...I figured that the ecm can figure it out.
not sure where to go from here since there are no codes.....
m
m
x3 on resetting the ECU, sometimes it will screw stuff up. Do you have a way to measure your AFR? I have had my ECU go way lean on me, and resetting the ECU fixed the problem... I need to fine tune my fuel maps more.
no way to measure afr at this time..
stupid question... where is the fuse? in the cab there are 2 fuses for ecu I think thay are labeled ecu-a and ecu-b one is 7 amp and 15 amp I think.
You can just pull the pos. battery cable off for a minute or two. The fuse I pull is under the hood, labeled EFI. It's a 15amper.
My supercharged 4Runner did what you described when the clutch was going out.The slipping started in 4th and worked its way to 2nd. I only got 5k miles from a brand new OEM . I've since put a stage 3+ spec clutch on it maybe this clutch will last longer.
Good advice on resetting the ECU though hopefully that will solve your issue's.
ripp96
07-25-2015 02:32 PM
mYnAmEiSmUd
07-20-2015 06:48 AM
