S/C oil question
You don't. The nose is designed for a 100,000 mile service life before it requires a rebuild or service.
If you MUST muck around with it, you can follow the oil change procedure documented in this manual on the TRD site; http://www.trdusa.com/installMan.asp...-17620-228.PDF
Keep in mind that it requires you remove the supercharger to removed the nose...
Originally Posted by TooEZgoin
What is the hex bolt for that has the painted seal on it in the front nose area?
Believe it or not I just went out and unscrewed the hex and no oil came out, and I could not see any pool of oil inside the gears.
The reason for my post is because 3 days ago my s/c started sounding like a coffee can full of marbles being spun around.
I have 200,000 miles on this s/c, most of it earned by towing a 2000LB+ construction trailer. I have never preformed any maintenance on the s/c.
It sounds like you are due for a rebuild then TRD offers rebuilt nose assemblies on a core trade in basis. Take a look at; http://www.trdusa.com/installMan.asp...-17620-226.PDF
WATRD once again gets you the correct info that helps out. I have been off the board for almost 2 years now and am just getting back into taking care of my 97 Runner. Thanks!
I also believe people went here to do a rebuild http://www.magnusonproducts.com/
the1998sr5
15
07-14-2020 08:35 PM
88yodabasket
07-13-2015 01:32 PM
