Rough Running '97 4Runner
Old 07-21-2009, 08:25 PM
2Broke2FixIt's Avatar
Question Rough Running '97 4Runner
I've been having trouble with a rough running engine in my '97 4Runner (3.4L V6). The problem first started about a year ago when it suddenly began to run very rough on the highway and my check engine light came on. I took it to a mechanic who said there was a misfire code and changed the spark plugs and wires.
The problem seemed to be solved for 4 or 5 months until it gradually began running rough again and eventually the engine light showed up again. Not wanting to shell out another couple hundred bucks I changed my own spark plugs to see if there was just some fluke with a bad spark plug.
Well, again, the problem was solved for another 4 or 5 months. But again, it has started running rough and the engine light is on. Any ideas?
I don't have much experience working on engines, but I consider myself mechanically inclined and a quick learner. I would really rather try to fix it myself, because I don't have the money to have it done for me.
Thanks!
Old 07-21-2009, 09:42 PM
whokrz's Avatar
There is a link to factory service manuals in my sig that you may find useful, they have pretty good trouble shooting guides.
I had a 97 4runner that I got a misfire code on and it turned out to be the fuel injector.
At the auto parts store you can buy a tool that reads the check engine light for codes for about $30 the one you need is for obd2. You will also need a ohm meter for testing components such as fuel injector.
Hope this helps
Old 07-21-2009, 10:42 PM
Godzilla's Avatar
Post/search the actual code to get a better idea of what is going on. Could be a few things like a bad coil pack.
Old 07-22-2009, 03:53 AM
jeremy9allen's Avatar
Did any of the spark plug tubes have oil in them?
Yont283
09-23-2022 08:06 PM
puffin04
07-10-2015 09:17 PM
TNRunner88
07-01-2015 08:00 PM
Alex Bessinger
06-28-2015 10:05 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
Quick Reply: Rough Running '97 4Runner
